great road.. just have to have respect for it... i use to do midnight runs on friday and saturday nights....
Simple rule... fast in the corners and slow on the straights
But only do this once u get to know the road well.. keep an eye out for the corner speed signs.. u wont want to add more than 5km/h on to them
Great rd.. have fun on it
https://www.sau.com.au/forums/topic/201167-old-pac/page/2/#findComment-3578242
  • Replies 60
Slow in the straights is politically correct generic advice. Well, adding 5km/hr to the signposted corner speed suggestions will still keep you under the speed limit so its also acceptable.
As for whether 5km/hr over the corner signpost speeds actually constitutes "fast" or not, I'll leave unanswered.
https://www.sau.com.au/forums/topic/201167-old-pac/page/2/#findComment-3578458
So why post?
Just so everyone is clear. Yes it's a windy road and no, we do not condone doing anything on it other than driving sensibly at or below the speed limit.
lol i was waiting for a SAU disclaimer.
its a nice drive. No where near as nice as macquarie pass.
https://www.sau.com.au/forums/topic/201167-old-pac/page/2/#findComment-3579240
I think thats one of things I look forward to when I goto mates places in Bathurst/Mudgee - Bells Line!!!
Apparantly theres a mad country road from Lithgow to Bathurst which takes alot longer than the GWH - I know JETR23, DJ Brave, mznismo, Sam916 couldnt stop raving about it when they came up and saw us race at Bathurst!
https://www.sau.com.au/forums/topic/201167-old-pac/page/2/#findComment-3579316
the road to Tarana, S%^t yeah!!! most awesome road, we need Wayne as a tour guide, its a beautiful flowing drive through the country with some nice open sweeping corners where you can see miles ahead and the od nice twisty one aswell :blink:. I vote for another roadtrip there sometime when I'm back over here visiting from WA. :D
oh...and you wont find it that easily looking on a map, you really need somone who knows the area, i don't even know if the roads are mapped.
https://www.sau.com.au/forums/topic/201167-old-pac/page/2/#findComment-3580307
your doing it wrong then ;) maq pass is awesome fun but they all have their merits, if your bored of driving it try drifting it :D
https://www.sau.com.au/forums/topic/201167-old-pac/page/2/#findComment-3580762
So is the natio run from syd to the gong...
Not if your car is low.
My car's at factory height and I bottom out repeatedly. Its worse north of the Waterfall entrance, but even in that bottom section through the trees there are a few spots I'll spark out.
That said, I took the girlfriend's MX5 through the entire run and it was great.
https://www.sau.com.au/forums/topic/201167-old-pac/page/2/#findComment-3580959
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
