  • Replies 176
Ahh thanks for that snap shot teejay... As soon as i seen it i was on the phone blasting those useless buggers i told them the car was not to be left out. So sorry guy`s your have to wait abit longer to have another looksie at least when i have had a chance to give it a wash.
:P
:P
:D
