  • Replies 176
and so......
cops wouldnt be able to work out what it is and wouldnt be able to catch it anyway
w00ps, did i just say that out loud??!!!
on another note - fabcar are taking a big risk by having there red stagea rs4 with noice 19's in armahole shopping city centre....
must be big insurance on that thing, cause im suprised its still there.........
Yeah sorry dan, must have been off running that plasma-drive civic when you got there.. PTEC YO!
It's not for Northside btw, both belong to Autowholesale or whatever they're called. I did hear that some of the Nissan bigwigs aren't too happy..
Edited by bubba
theyre friggin nice cars.
here's me checking one out :D
on the outside they look like a big car and on the inside i had tons of room (6'4). its sex on wheels.
only 80,000 odd AUD$ over there :(
I got more pics of them in every colour if anyone is interested.
Shaun
Edited by RadiuM
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
