Went to order a set of the Noltec front upper camber adjustable arms for my 32 gtr today, and have been told they have been discontinued... now I'm looking at the Silk Road front camber arms as they seem to be of the same design/principle... has anyone bought these? or seen them in the flesh? just trying to gauge adjustability/reliability I guess...
I've also looked at the Midori front upper links but I'm not too keen on paying $650+ when the Silk Road arms are ~$350.
https://www.sau.com.au/forums/topic/201556-silk-road-front-upper-camber-arms/
  • 1 month later...
well they are chinese made (section/silk road) so i would not want to pay too much more than 350, the midori ones are made in japan and were copied by many like KTS (also taiwan) etc.
if your happy with the silk road ones check out driftshop.com.au and ask costa if he has his version in stock... im sure they would be the same thing and as far as cheap arms go his are the better of what is available here. I ve used his stuff a bit when in a bind and it has alsways been better than the other generic stuff.
They are a bitch to adjust, you can't get to the locking nut while the arm is connected. You will pay more for every wheel alignment as a result.
Cheers
Gary
http://cgi.ebay.com.au/D-Project-FRONT-CAM...7QQcmdZViewItem
are the driftshop ones you mentioned URAS?
SK, have you seen these used? I know you aren't a fan of having everythign so solid...
Haven't seen them in use as yet, won't be long though, without dust seals and grease retention they won't last very long. So I will have guys PM'ing me for advice on how to stop the knocking.
Hard to tell exactly from the pictures, but their minimum length looks too long for sufficient negative camber on the high speed tracks (eg; Philip Island)
Cheers
Gary
yeah making the lower arm longer is a good thing. gives you more track as well as the camber you need. the only reason people don't do it more often is the cost. typically the lower arms cost more than double the uppers.
Plus it always screws up the bump steer something fierce, often changes the Ackerman and does no good at all for the dynamic camber change. If you fix those things then, yep, longer lower control arms work fine.
Cheers
Gary
Yeh, not sure what it does to bump steer but assumed it woudl be bad for ackerman.
Im slowly learning with cars. Keepign it simple means the best results. To get stupidly good results you either need to own a GTR and have a workshop that has done all the R&D or wear the cost yourself. Stick with the Noltec arms, or speak to UAS about his replacement arms that he is bringing to market very soon, they look to be good things for the R32/Z32 range that can chew bushes when you run too much camber abd castor
Can't help you with if they are any good - But where are you getting them from at that price?
Greenline
I went ahead and got the Section arms, they are made rather well but I can see what SK means by being a bitch to adjust, you basically have to pull them out, reset, and put back in, I installed them on their lowest camber setting (pulled all the way in), and I didnt get much negative camber at all... :blink:
Would it be super dodgey to slot the mounts? :thumbsup:
....speak to UAS about his replacement arms that he is bringing to market very soon...
I sent off an e-mail to UAS.
Checked my mail today and recieved an e-mail on from UAS on Monday, "...waiting to get an eta but suspect next month and they are the best on the market and unique in design"
Stay tuned
two years no greasing with regular checks (i would suggest checking after a trip into the sand traps though :) ) and still going strong with nil play..... these are used in most of japans fastest super lap cars.
http://www.nagisa-auto.com/
Far more than just cheap chinese arms, most have rc + bs correction and so forth in built.
Greenline
I went ahead and got the Section arms, they are made rather well but I can see what SK means by being a bitch to adjust, you basically have to pull them out, reset, and put back in, I installed them on their lowest camber setting (pulled all the way in), and I didnt get much negative camber at all... :)
Would it be super dodgey to slot the mounts? :)
Most of the retail camber kits are designed to REMOVE the negative camber that occurs when Skylines are lowered. This is because the “road car market” is far larger than the “race car market” and they are looking at excessive inside tyre wear as the major problem that they need to overcome by adjusting the camber. For reference, the standard R32 style upper control arm is ~180 mm long, centre of the outer bolt to the centre of the inner bolt. Using the off the shelf adjustable, offset, outer bush (Whiteline etc) reduces that to ~175 mm. This gives around 2 to 2.5 degrees of negative camber on an R32 with a ride height around 355 mm centre of wheel to guard with around 6.5 degrees of caster on a 2wd and 5.0 degrees on a 4wd.
That is usually enough camber/caster, provided sufficient anti roll is used (larger stabiliser bars), for most circuits. High speed circuits with long sweeping radius curves (eg; Philip Island) need slightly more camber.
So we use the off the shelf adjustable, offset bush (Whiteline etc) in the inner of the upper control arm. That reduces the length to around 170 mm. This gives around 3.0 to 3.5 degrees of negative camber on an R32 with a ride height around 355 mm centre of wheel to guard with around 6.5 degrees of caster on a 2wd and 5.0 degrees on a 4wd.
This 170 mm length seems to have been the minimum that ALL of the R32 camber adjusters have been made to. Of all of the brands of upper control arms that I have measured (Noltec, Nismo, Ikeya etc) the minimum is 172 mm. many are longer. So choosing one brand over another to get more negative camber is pretty much a waste of time.
Keep in mind that when you add caster, the R32 designed upper control arm has no choice but to distort the bushes. Hence they become a consumable item, you simply have to change them regularly. Just like brake pads, the bushes wear out and need replacement. This is why Nissan changed the design of the front upper control arm on 33's and 34's.
You can't easily slot the outer holes due to the design of the upright (hub). If you slot the inner holes enough to make a worthwhile difference, the arm rubs on the inner guard.
Cheers
Gary
Gary,
Here is the Cusco fixed arm I just bought. (Thanks Tacker :)) Centre distances are 172mm. Unusually they use a common bearing: 6203Z if anyone cares. I was going to knock those out & replace them with some bushes.
Also of note is the amount of stagger, ie how far the inside is behind the outside is 23mm. Not sure if adjusting this would help generate more castor without negative side effects.
Edited by djr81
Gary,
I think you may have confused the stock length with the adjusted length. From memory the stockers are 182 centre to centre.
Thanks, I should learn to never rely on my failing memory, post amended accordingly.
Cheers
Gar
Random question:
You can move the bottom of the upright forward for more castor. But given the arm has stagger built in, can you move the top further back? That assumes you fab up your own arms - which isn't hard looking at the Cusco ones.
Edited by djr81
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
