  • 2 months later...
  • Replies 54
  • 1 month later...
  • 3 weeks later...
Having FAST is all well and good but can anyone get a hold of the nissan australia software that actually spits out the prices ?
No can do buddy.
The dealerships use FAST to find out part numbers only. They then take that number and put it in a completely different system which controls their ordering/stock taking etc and I imagine that even if you could get the software on your PC you would still need to have a connection to the dealer network for it to be of any use.
  • 1 year later...
Hi there guys does any one know any good sites for downloading this?. I have the 1.56 gig copy and it keeps saying i dont have enough space on my Hard drive for it when i have 120 gig free!..
Any ideas guys
Can anyone help i cant work out what to do? if anyone has a simple way of downloading it so it runs without having to download a million other item that would be good.
My copy which is the 1.56gb one works fine. just follow the instructions that should come with it and its fairly simple to install. If for some reason yours didnt come with instructions PM me and ill send you a copy.
At which stage are you getting an error?
Check all of your file paths in the setup.
+1 above
ill try and zip the copy i have its not the newest version tho think instrustions are with it still.? ill make certain all files are there so give me time pleasejust make certain that you check all file paths thats where i was having troubles.
give me sometime and ill put a link up ok maybe mmmmmmk ok :devil:
  • 5 weeks later...
No can do buddy.
this is correct. they run 2 programs at the same time and swap back and forward to transfer part numbers. you will need to be on the same system as them as they can acsess interstate systems to orderparts and get prices on stuff they dont carry. i asked the spareparts guys at work if they would lend me the program and they just laughed. apparently unless your a nissan dealership you shouldnt even have that program.
well of course.. thats how nissan dealers make their money. techs dont have to fault find anything these days :sick:
on a similar note on topic, does anyone know if it can be used to turn off the "key in ignition"/lights on/door open chime on my 99 stagea?
i dunno how nissan software works but i work for mazda and theirs you can change most alerts on the car.
if its anything like the r32, you unscrew the panel that sits above the drivers knees - attached to that is a relay - if you unplug the relay it'll stop the alert
-D
well of course.. thats how nissan dealers make their money. techs dont have to fault find anything these days :P
not sure if you can on a stag but you need a nissan consult to do that. got to go to a nissan dealership bro. will cost ya at least 100bucks. hahahaha.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
