well just thought, i would anounce i have a black r35 coming which should be hear in april and i cant tell ya how excited i am!!!!!
hopefully a few guys on this forum can make it out to the track when it gets hear, as we will try to get it out to QR before we start changing it.
i intend to have a section of the build process on that and the r34 timeattack car.
russ
https://www.sau.com.au/forums/topic/201859-black-r35-coming/
  • Replies 57
Ahhh, you guys built the crazy R32 GTR that recently raced at Tsukuba? Congrats on all the success :blink:
And congrats on the R35. Lots of us are dying to see how they go with mods!
Damn you have lotsa GTRs, how about spreading it around a little mate? :blink:
Nice work Russ, any particular modification plans for the R35 when it arrives?
Nick
r35 will get caged, exhaust , hopefully ecu modifier of some description for boost fuel timing & speed limiter, terratrip, seats, harness
it will be stripped out of alot of interior and not much else at this stage, want to be able to run buller and things like that.
the r34 will be 3ltr, autronic, hollinger, v8 supecar brakes, full ikeya arms, carbon doors and bonnet, caged, single seat, as light as possible for pure time attack events.
nearly all these parts are here just waiting for the bloody car!!
yeah too many gtr's! (mind you they are mark's as well!!)
my wife is really getting the shits and had enough!
but i just cant help it a lovem!! and just amazed at the new car that nissan have delivered!
Edited by giant
Before the R33 goes i so would love to see some footage of it being driven in anger :blink:
hey roy , it,s coming mate!
we stuck into it over christmas , all new fuel system , pulled the engine back out and dry sumped it, engine should go back in.
i would say it will be on the dyno in two or three weeks, want to have it finished before starting anything else,
want to do a few events in it before selling it! probably do gatton street sprints up here in march.
so i will have vids of it and pics of car sometime soon.
what would be the best optin shan?
i was going to rally rego it
well if you're gonna go balls out and race mod it then you'd probably be better off with a race import. it'll also see the car in your hands faster.
if its gonna be sedate mods then putting it on the road might be more fun/profitable when you want to sell it down the track. that said, it'll be at least 6 to 8 months before anyone can comply em.
i'd go the race import, easier, quicker and cheaper.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
