Hey guys,
ive tried researching this & have searched various threads also. My R33 has quite hazy headlights which can be riden with various products such as Mother's Plastic Polish etc. Wat im wanting to do is remove the scratches on the lights, im wondering if anyone has used these novus products to do so?
http://cgi.ebay.com.au/NOVUS-Plastic-Polis...1QQcmdZViewItem
First two products seem theyd work a treat but i dont know about the third, mayb a lil too abrasive. I dun want to ruin my headlights cos a new pair wuld cost a bundle...thanx in advance! :D
https://www.sau.com.au/forums/topic/201909-cleaning-r33-headlights/
Personally, I just used some extra cut cream polish (for paint) and they came up pretty good. No need for these "plastic specific" polishes, all the same stuff i reckon, just re-packaged to jack up the price.
I agree. Mine were really bad when I got the car, my mechanic said to hit it with some 1200 wet/ dry, then cut and polish. They are as clear as glass now, looks so much better. I usually cut and polish them every few months as they start to go a bit cloudy again.
I've cut and polished mine - looks alot better than when the car first arrived... but it still has some yuckiness to it - it look as though its on the inside of the headlight... should I keep going with the cut and polish?
I'd say yes. I did mine about 10 times to start with, each time getting better and better until it was perfectly clear. When they are wet do they look good? Usually they do and that suggests that everything is on the outside. Might I add they didnt look too bad when I saw your car at Auto Perfection the other day, nice car. They didnt put a sticker on my car, did you get one?
Not sure on the wet thing but probably take a look at it again later - can definitely see the yuckness in the sun.
And yeah I got a small sticker just underneath the rear windscreen wiper.
Hey all.....is it just the 33's that suffer from this or do the 32's & 34's have the same problem.....mine seem pretty clear.
I suppose it's a combination of fall out and UV that causes the problem?
They all do. My old 34 suffered as well, and fixed it with some plastic polish (and lots of scrubbing).
use Autosol metal polish. they come out fkn crystal clear!
Yeah I use something similar on the bike's stainless steel just before a show and you can't tell if it's stainless or chrome.
'Liquid Reflection' metal polish.
Il be giving that a go soon but any idea how to take the clear cover of the light so i change the chrome to black?
u gotta heat the plastic up and pry the cover off with a screwdriver, its sealed on with urethane :)
Damn those headlights were filthy!
thats actually what the lights look like after sanding them :(
the pic quality wasnt too good cos i used my phone cam
all we do at work when we get 2nd hand headlights and they are like that is just get cut n polish and scrub away and they look like new! we just use the normal cut n polish you use on the car paint. works fine
Before trying any expensive polish, try getting a rag/cloth and rubbing toothpaste onto the headlights. Its not perfect but I've found it does give quite good results. Just make sure not to get any on the paint!! This goes for any cut and polish as well. Normal polish is ok on paint but cut and polish will normally wreck your metallic/pearl paint.
Pretty sure all skylines have this problem with faded headlights. Stageas are the same too. :)
  • 1 year later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
