That's sux...what am I going to do with the boost controller then!!!...lol.
P.S. How sure are u that it is ceramic turbo? I have my doubts!...will let you know soon though as I am pulling it out to get high flowed and steel impellers(I think). New dump pipe and new high flow cat is also going in.
I've been lead to believe they're ceramics from reading it here somewhere. I know there's a guy who pulled his turbo out, i'll find that post.
  • Replies 40
This thread, MX? http://www.skylinesaustralia.com/forums/M3...cs-t192998.html
It's from Stag250, and he states that he believes the turbo IS the same as the RB25 units in s1 and s2 C34's.
Yes that's the one. I was hoping he would mention something about the unit before it got reconditioned.
If it's the same as the RB25 turbo units in the S1 & S2 should I not have bit's of ceramic spitting through the exhaust....hope not...lol :0
Mine's at 1.09bar(15.5psi)....and my turbo is standard(I think!). What were the RB25's good for?
Edited by Jetwreck
it was a ceramic unit and it is now steel correct
Don't know what mine is! Pretty sure it's whatever comes standard. Before you reco's yours STAG250, was it definatly 100% ceramic?
yeah 16psi will well and truely kill a ceramic turb. 12psi is about as high as you can go safe.
and now I know how you were keeping up :cheers:
Then I cannot have the same turbo's as the RB25's....hmmmm...more research needed.
P.S. Been waiting all week for a special letter from the RTA on that keeping up thing.....never came...phew!!!
well the moving parts were but I confess I didn't see it myself out before it was recon'd but merely repeat what I was told by the recon guy and the mechanic
  • 4 months later...
I just fitted a boost gauge to a stock standard ARX and the boost maxed out at 15psi and settles back to 14 psi under full load.
I think we need to find out what our turbo's of made of because if they are the same ceramic turbo as used in the older model stagea with the NEO motor the turbo may not last that long.
The part number for the the turbo fitted to my car is. 14411-AQ800-. Any one know how to find out what sort of turbo this is and what/ how it is built?
Cheers
Andy
Edited by andy65b
Cheers
Andy
Hey guys. Just got my car back on Friday night from the Shop.
Hi-Flowed turbo... The stock one is DEFINATELY ceramic (I saw the bits).
The receipt I have states that the Hi-Flow turbo uses a Garrett T3 core.
The stock boost for my car was around 7-8psi so I am let to believe. It has been set at 10psi and the boost controller has been disconnected to keep it there until I get my exhaust as I still have a fair amount of restriction there.
As an aside, it makes 140awkw.
I have found that it behaves a bit more like a NA engine now and is much quieter (do you guys find your turbos to be rather loud?).
Interestingly instead of light boost at 2500 rpm & full boost at 3200 until it tapered off at around 5000rpm, it now starts spooling at 2k and is still going strong at 6500!
Cannot wait to get that exhaust.... although I feel a saga comming on....
not sure what is going on with these boost numbers. Mine is absolutley stock and is definatley hitting 15-14psi. So why are they telling you 8psi?
We definatley need more info on the turbo's!
The previous shop I took it to put it on the Dyno which showed 8psi stock... although that was the same day as the infamous 0.6psi (not a typo).
The shop that did the hiflow did not dyno it before hand. Makes me think that it would be quite safe running 15psi with steel internals then, no?
I spoke to Ben at North Shore Prestige Motors today and he said standard boost is 0.8bar (11.6 psi).
I am getting 14psi (0.965bar) at max throttle. (with an absolute peak of 15psi)
He also said the turbo is quite unique and nit eaisly replaced. I ame getting some more details later this week. He did say that the turbo is quite different to the turbo on the older stagea's.
Cheers
Andy
Cheers
Andy
It is the housing & flange that is VERY different. The internals are rather similar to the RB25 turbo but certainly not the same.
is it a T3 flange??
Just going by what I have been told by a couple of shops that have hi-flowed m35 turbos...
The housing & flange are different (both shops said that they would "not want to break it" as they don't know where they would get another - neither had seen t before) but the T3 internals were used to hi-flow mine.
Take from that what you will.... :)
  • 3 weeks later...
holy shit! thats not really a good sign lol
maybe there are some SS manifolds around that change the flange to T3 or something, easier for upgrades
I don't know what a "normal" turbo outlet is but this is what the vq25det turbo outlet looks like...
Edited by iamhe77
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
