lol, not even the fastest bullet trains cover those distances in times like that. :)
btw, there is no kosaka station...i just checked?
i reckon your Brie is spiked, Laurence. :ermm:
Stick to Camembert, best cheese in the world. You should recommend it to GTR man the next time you see him.
Edited by m3gtr
  • Replies 65
Posted Images
LOL! this little convo was best suited to the pages of MSN..
cant wait to see the flaming ill get over this one! :ermm::)
I can just see it now.. " Thread closed due to multiple Brie, boob job, beer can and bread loaf breaches" :rofl:;)
Edited by m3gtr
I was thinking that the R35 rear drive shafts are 6-bolt, but spaced out like the 5-bolt ones of before rather than the 3-pairs of bolts that people refer to as the 6-bolt now. Now when people start using those drive shafts in other cars, what will they refer to them as. 6-bolt? That would be confusing...
All they had was gouda :ermm:
:ermm::):rofl:
Cleen yo dam kayboard Lawwrence.
yep, i wonder if my man the plastic surgeon didnt actually have a Vspec version ( V as in viagra, lol )...
I could have sworn the accessories inside the car werent standard equipment...were they manual or auto?
Only one way to find out, really...
Edited by m3gtr
Those marks are errr, compression artefacts... jpeg stuff, yeah, that is it.
Osaka is just a dirty town, it is how we roll.
you big fat liar.
This is how a keyboard should look..and i always thought TKY was way dirtier than OSA..at least girl wise anyway...
You can keep your brie and goronzola...im sticking faithfully to my Camembert..AHEM..my ummmm....R35... GTR...Hokkaido Camembert V spec..errr.. edition,.,.yeah... :ermm:
Edited by m3gtr
Try Kawachi-Kosaka...
Hehe... between ゴルゴンゾラ、小阪 and いちーばん I reckon you might need to get that keyboard checked out... :ermm:
edit: Nice cheese by the way... hmmm I should have got some too
Edited by Laurence
Lookin into it as we speak... Thanks for the heads up.
Bloody Mac always givin me the shits ...(grumble, grumble..)
yep..im leaving it out overnight so itll be room temperature frozen tomorrow morning for the toasties...
Edited by m3gtr
since this thread has degenerated into a random discussion (without any help from me I might add!) I will use it to reply to a post in your last thread directed at me:
Your comment about not really caring about material possessions is interesting.
Car gets stolen, insurances cuts me a cheque. case closed game over.
Interesting. No emotional attachment>? I doubt that very much. Lets say someone just inadvertently stole your R33 and it was never recovered. Just cut a cheque and let a dead dog lie?
1. I never said I don't care about material possesions. I love material possesions. I am a material girl, in a material world. I buy as many expensive consumer products as I can get my hands on.
2. I have had one of my R33 GTRs stolen before. and it was not recovered. and yes my insurance company promptly investigated, then handed me the cheque. I banked it and moved on. I was pissed off when it happend but yeah about 30 minutes after I got the cheque I was over it. I didn't lose any money, just a bit of farking around. As much as I love it it's just a car after all and it wasn't the last R33 GTR V Spec on the planet so no point worrying about it. It's probably in UAE somewhere right now, I hope the new owner enjoys it.
RIP Silver Car :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
