Rb26 With Twin Afm's, If I Get Them Mixed Up Will The Car Not Start?
Hey guys, im trying to figure out why my car aint starting, i suspect my cas is the fault(as we dropped it), but i was thinking, if the AFM's were switched when plugged in, would this cause the same problem???, im sure ive plugged them in correctly, but just want to make sure,for me to test this though, id have to remove the arc air box etc, bt of work invloved, as one of the plugs can only reache to the afm, which is the reason why i think i have them setup correcty....is there an easy way to test this???as my car aint starting at all right now!, will my car start without the afms plugged in?
thanks
Edited by nsta
None of the above will stop the car starting. Check for trouble codes in the ecu. Have you puled the cas out and turned it by hand to see if the injetors are clicking yet? A troubled CAS will pull a trouble code in the ecu.
Hey, yes when i turn the cas unit, i hear the injectors clicking.....does this mean that its working fine?, i just refitted my new head, and since its not working.....Timing is spot on, when i turn the keys, car almost starts, then a vacuum sound comes through the intake, and then nothing....i dnt know what it is...
If i can hear clicking in the injectors with the cas unit, does this usually mean that the cas unit is fine?
Replaced cas, car started immediately, but was running very rough....is it usual for my engine to have noisy lifters for awhile after replacing headgasket and doing a bit of headwork?....im scared as someone said thats usual, while another said that could be your valves bent:(.....knocking in other words...i dont know how to tell the difference, someone is coming to have a look at it tommorow....
Well the timing and everything is spot on, i removed everything and rechecked, but my car seems to be still rattling, i thought it was the lifters, as they were noisy before i even replaced the gasket(when the motor was fine)....but this sound is amplified by 10!, i mean the more revs, the more noise they make, which makes me think they are knocks, im getting a mechanic to check today...
Thats something the head reconditioner's would have done (hope they did)......could this be the noise?, if so, im going to be annoyed if i have to remove head again because of something they didnt do......
i did recheck the timing, and it was off by maybe a tooth, so im going to get the guy whos coming around to redo the timing and see if that helps, will having the timing off by a tooth cause bent valves and danger zone?....i heard someone who was out by 2 teeth and was running shit performance, but fine otherwse.....
Im crossing my fingers its not Big ends (knocking).....could knocking occur due to wrong timing?
If BB says it can get noisy then yes that could be the noise :(
What head work did you get done? Was there cam work? Maybe the head guy thought your tuner would do the clearances.
You can set the clearances with the head on - just need to take the cam covers off (no shit huh?)
incorrect valve clearances will definitely give you a noisy valve train and often it's difficult to pick bottom of engine noises from head noises. it's possible they didn't think it worth checking (unlikely), or maybe couldn't get a hold of the shims needed (less common these days, than it used to be), but I wouldn't point the finger just yet. this is just a diagnosis phase. I don't think having the timing out by 1 tooth would cause any engine damage, but at the same time I wouldn't promise that it wont either. get that fixed and try again. some one with a good ear for RB26 should be able to tell you what the noise is. It can be tough as there are lots of noises going on. injectors are noisy, clutch fan is noisy, and the valve train is a little noisy too (though usually not as loud as the injectors).
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
