Rb26 With Twin Afm's, If I Get Them Mixed Up Will The Car Not Start?
Hey guys, im trying to figure out why my car aint starting, i suspect my cas is the fault(as we dropped it), but i was thinking, if the AFM's were switched when plugged in, would this cause the same problem???, im sure ive plugged them in correctly, but just want to make sure,for me to test this though, id have to remove the arc air box etc, bt of work invloved, as one of the plugs can only reache to the afm, which is the reason why i think i have them setup correcty....is there an easy way to test this???as my car aint starting at all right now!, will my car start without the afms plugged in?
thanks
Edited by nsta
None of the above will stop the car starting. Check for trouble codes in the ecu. Have you puled the cas out and turned it by hand to see if the injetors are clicking yet? A troubled CAS will pull a trouble code in the ecu.
Hey, yes when i turn the cas unit, i hear the injectors clicking.....does this mean that its working fine?, i just refitted my new head, and since its not working.....Timing is spot on, when i turn the keys, car almost starts, then a vacuum sound comes through the intake, and then nothing....i dnt know what it is...
If i can hear clicking in the injectors with the cas unit, does this usually mean that the cas unit is fine?
Replaced cas, car started immediately, but was running very rough....is it usual for my engine to have noisy lifters for awhile after replacing headgasket and doing a bit of headwork?....im scared as someone said thats usual, while another said that could be your valves bent:(.....knocking in other words...i dont know how to tell the difference, someone is coming to have a look at it tommorow....
Well the timing and everything is spot on, i removed everything and rechecked, but my car seems to be still rattling, i thought it was the lifters, as they were noisy before i even replaced the gasket(when the motor was fine)....but this sound is amplified by 10!, i mean the more revs, the more noise they make, which makes me think they are knocks, im getting a mechanic to check today...
Thats something the head reconditioner's would have done (hope they did)......could this be the noise?, if so, im going to be annoyed if i have to remove head again because of something they didnt do......
i did recheck the timing, and it was off by maybe a tooth, so im going to get the guy whos coming around to redo the timing and see if that helps, will having the timing off by a tooth cause bent valves and danger zone?....i heard someone who was out by 2 teeth and was running shit performance, but fine otherwse.....
Im crossing my fingers its not Big ends (knocking).....could knocking occur due to wrong timing?
If BB says it can get noisy then yes that could be the noise :(
What head work did you get done? Was there cam work? Maybe the head guy thought your tuner would do the clearances.
You can set the clearances with the head on - just need to take the cam covers off (no shit huh?)
incorrect valve clearances will definitely give you a noisy valve train and often it's difficult to pick bottom of engine noises from head noises. it's possible they didn't think it worth checking (unlikely), or maybe couldn't get a hold of the shims needed (less common these days, than it used to be), but I wouldn't point the finger just yet. this is just a diagnosis phase. I don't think having the timing out by 1 tooth would cause any engine damage, but at the same time I wouldn't promise that it wont either. get that fixed and try again. some one with a good ear for RB26 should be able to tell you what the noise is. It can be tough as there are lots of noises going on. injectors are noisy, clutch fan is noisy, and the valve train is a little noisy too (though usually not as loud as the injectors).
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
