I recently bought a s13 and have been wanting to do a 25neo swap. I live in the us so neo motors are a rarity and the only place I can find them are from those sketchy canadians up north. And from them who knows what your gonna get. I can find r33 25's all day even in the states for a little extra but I dont know the potential I would be missing out on. I've heard a lot of good things about the neo besides the price of clutches and was wondering your thoughts. From what I here if anyone would know about these motors it would be you guys.
https://www.sau.com.au/forums/topic/204915-r33-rb25-vs-r34-rb25/
well, for starters, I'm pretty sure the NEO's are fitted with RB26 rods from the factory so that would make them stronger.
They are also 9.3:1 Compression as opposed to the 9:1 compression of the R33 RB25
I've read they also have solid lifters and the vvt as apposed to the r33's but I was wondering if any body has pushed them and if they really mad more reliable power than the r33's.
The NEO tends to make more power for the same amount of mods better breathing due to head package). They are both as reliable as each other but the Neos' tend to have lower mileage which helps.
interesting, can anyone back this up?
Also consider the availability of aftermarket turbo kits and ECU's (ie Power FC). Mods for the 33 are more readily available and cheaper than for the 34. NB: PFC are discontinued for RB25's
turbo kits from R33 fit perfect on R34, i do it all the time with the trust kits.
Bloody net dropping out!!!!!
Here we go, I'll retype again...
NVCS is only on one cam.
They run narrow body injectors
Stock turbo is weaker when boosted due to nylon comp wheel, ceramic exhaust wheel like r33
Mate Ben has R34 GT-T
Stock engine
tomei poncams 260
800cc inj
044
fuel reg
z32
power fc
front mount
plazma man plenum
T04Z
363RWKW @22 psi Z32 starting to max out.
He has a built RB30 bottom end to swap in due to nos system he intends to use with setup, no bull.
The way I look at it is that it makes a bit more grunt in factory trim so that can't be a bad thing . The electronics running it are a bit more advanced so if you can get control of those then its tighter controls IMO .
I think the non hydraulic buckets are a bonus and will open up your choice of cam profiles . If you really want to I'm sure there are ways to get larger injectors into them .
Also don't write off RB26's if you can get them for reasonable money , a few people have used those in the US .
Further O/T . If I was over there I'd be doing a killer KA24DE-T because there are so many parts available for them and they are std (DE) in a USDM S14 anyway . I guess its a case of how much your prepared to pay to be different . I don't remember the exact cc figures for both KA24 and RB25 but there's probably only 100cc's in it if that .
Cheers A .
And an extra 2 cylinders bobbing away in the RB? Surley that counts for something?
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
    • I don't know what you should expect with an LS, but the oil pressure sounds terrible, sorry. As for the brakes, you can get fade from the pads not just the fluid, although generally that feels like a wooden block not doing anything while fluid feels like an oh shit there is no pedal so you can generally tell. What pads are you running front and rear?
    • Went over my datalogs on a whim and noticed a worrying combination of events. High RPM High Temperature Low Oil Pressure Knock Retard I bought some 10w-60 because I actually think this will be better going forward given track temp is 125C and 10-40 will actually be thinner in those environments. I know I had a leak but it's not entirely sure how much pressure loss can be attributed to that. The knock retard does correlate with all of the above. When it's not present oil pressure is higher. And by 'low' I mean at 6800 RPM the oil pressure was recorded as low as ~35psi pretty constantly. Which is obviously very not good. I'm hoping that thicker oil that ISNT LEAKING will result in a bit more pressure when I need it. Also in the last session I got a very spongy break pedal. I bled the lines as the car is on jack stand right now with the wheels off and I noticed... no air in the lines? Maybe the tiniest bit of tiny frothy bubbles for the first 0.1 seconds of bleeding the whole car? The breaks did come back to me after I backed off (and felt fine driving normally). Doesn't appear to be any leaks anywhere that I can see. Any thoughts on that?
    • Solution, run shitter tyres. Let wheel spin be your weak link 😛
