I recently bought a s13 and have been wanting to do a 25neo swap. I live in the us so neo motors are a rarity and the only place I can find them are from those sketchy canadians up north. And from them who knows what your gonna get. I can find r33 25's all day even in the states for a little extra but I dont know the potential I would be missing out on. I've heard a lot of good things about the neo besides the price of clutches and was wondering your thoughts. From what I here if anyone would know about these motors it would be you guys.
https://www.sau.com.au/forums/topic/204915-r33-rb25-vs-r34-rb25/
well, for starters, I'm pretty sure the NEO's are fitted with RB26 rods from the factory so that would make them stronger.
They are also 9.3:1 Compression as opposed to the 9:1 compression of the R33 RB25
I've read they also have solid lifters and the vvt as apposed to the r33's but I was wondering if any body has pushed them and if they really mad more reliable power than the r33's.
The NEO tends to make more power for the same amount of mods better breathing due to head package). They are both as reliable as each other but the Neos' tend to have lower mileage which helps.
interesting, can anyone back this up?
Also consider the availability of aftermarket turbo kits and ECU's (ie Power FC). Mods for the 33 are more readily available and cheaper than for the 34. NB: PFC are discontinued for RB25's
turbo kits from R33 fit perfect on R34, i do it all the time with the trust kits.
Bloody net dropping out!!!!!
Here we go, I'll retype again...
NVCS is only on one cam.
They run narrow body injectors
Stock turbo is weaker when boosted due to nylon comp wheel, ceramic exhaust wheel like r33
Mate Ben has R34 GT-T
Stock engine
tomei poncams 260
800cc inj
044
fuel reg
z32
power fc
front mount
plazma man plenum
T04Z
363RWKW @22 psi Z32 starting to max out.
He has a built RB30 bottom end to swap in due to nos system he intends to use with setup, no bull.
The way I look at it is that it makes a bit more grunt in factory trim so that can't be a bad thing . The electronics running it are a bit more advanced so if you can get control of those then its tighter controls IMO .
I think the non hydraulic buckets are a bonus and will open up your choice of cam profiles . If you really want to I'm sure there are ways to get larger injectors into them .
Also don't write off RB26's if you can get them for reasonable money , a few people have used those in the US .
Further O/T . If I was over there I'd be doing a killer KA24DE-T because there are so many parts available for them and they are std (DE) in a USDM S14 anyway . I guess its a case of how much your prepared to pay to be different . I don't remember the exact cc figures for both KA24 and RB25 but there's probably only 100cc's in it if that .
Cheers A .
And an extra 2 cylinders bobbing away in the RB? Surley that counts for something?
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
