  • Replies 41
No idea,
Bought it in japan.
Turbos not included,
Looks to be a r34 n1 motor. 3000km since rebuild. and owner not sure what the rebuild was. as he bought car with the motor just rebuilt. and since crashed car.
will be getting a dry sump, my current turbos, and possibly rods and pistons when it gets here will run around 1.5-2bar and hopefully see around 400-500kw and to destroy my friends sprinter around the track
Edited by Angus Smart
Can anyone shed some light on the twin vs single turbs set up?
Im thinking about a turbo upgrade on my gtr also, to something like two 2530's.
What would the pro's and cons of going a single turbs over the twins be?
More lag? Cost? Complexity? compatibility with the power fc I have???
Just asking coz Im not sure, and those single turbo engine bays look incredible!
tah...
^^ I agree, its just a bearch to do in the first place :)
i think it`s just not bolted down !!!
I was thinking that, but it looked kinda funny. I thought maybe Steve was trying something fancy; so it clears something... or something - ha :P
^^ I agree, its just a bearch to do in the first place :D
I was thinking that, but it looked kinda funny. I thought maybe Steve was trying something fancy; so it clears something... or something - ha ;)
No such luck, nothing special going on there :blink:
All depends on your goals and how much money you have, do a search, hundreds of threads on it.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
