Hi all, is this normaly for a r32 rb20det to drink so much fuel.. i put 35L and only got 200km out of it and did not thrash it much and its got a tacho for air/fuel mix and it always goes to rich when i put my foot down.
***mods***
-turbo off R33
-mines ecu
-front mount
-3" turbo back exhaust
-boost on 10
-BOV
thanks for any help, please let me know if its normaly to be wasting that much fuel cause of the mods it has.. or is it bad??
Cheers
https://www.sau.com.au/forums/topic/205608-r32-is-this-bad-or-normaly-fuel/
AFR guages are useless....just for looks, dont really serve a purpose as when you put your foot down the ecu goes into closed loop mode (i.e. does not use the 02 sensor to figure out the rite AFR it just uses its Air flow meter reading and calculates exactly how much fuel it needs). The 02 sensor is for lite throttle tuning for the ecu. Im assuming its hooked up to the 02 sensor like every other one iv seen.
Turbo motors are tuned this way (when you put ur foot down) in order to keep detonation down. Turbo motors are more prone to detonation than N/A engines and hence adding more fuel reduces the amount of detonation. Hence when you put your down the AFR guage goes straight to rich.
As for you economy...i get anywhere from 400km-450km from a tank (60L). So from 35L thats about rite. I wouldnt be complaining.
put it on the dyno and see what afr its really pushing (my bet in the 10's despite the "mines ecu"), and those gauges are as useful as tits on a bull (unless its a proper wideband)
get it tuned properly, you'll notice a massive difference in ecomomy and power
It actually goes into OPEN loop mode when you put your foot down. CLOSED loop is at idle or cruise (vacuum) and uses the O2 sensor output to regulate fuel input.
I also get similar consumption as you.
Edited by bubba
I run wideband, and the engine stays closed loop (14.7:1) even on light boost. So - shouldn't go straight to rich.
I also get ~ 10lt/100km despite caning it, but I am running a 3.7:1 diff and the car only weighs 1090kg.
Sorry my bad...shud have referenced my engineering textbooks for that one (i struggle to remember the course after i pass it!) haha...indeed it goes to open loop when you put your foot down, i.e. it doesnt use the 02 sensor to regulate the fuel requirements....but when on light throttle it goes into closed loop mode.
Im not talking as in the second u put ur foot down, but as soon as boost and revs begin to wind up a bit (4000RPM +) it will wind out to rich...
Ok thanks mate, its my first turbo car so i dont know much about them but i dont mind if its alco on fuel :( cause there fun to drive and its worth it.
Thank you.
I got 495kms from 59litres of fuel in rb20det A31 the other day. Sedate driving. Rarely going past -0.2 bar vacuum on the boost gauge. So try to control your right foot and you can get even better economy.
Edited by robots
brothers rb20det r32 gets around 9-10L / 100km's. his runs rich (dyno to indicate this). so i think your economy is out the window, something is most likely wrong
I think your right.. because even my mates say my car wastes heaps of fuel even if i dont thrash it still drinks to much compared to there cars.. so i will take it to the mechanics tomorrow and see what they say.
Thanks everyone for your time.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
