Hey guys,
Ive been scrolling the forums for infomation directly about Injectors but not much is about the differences with them.
Its pretty obvious the more CC, the more fuel they squirt and the higher you go, the more HP you will be aiming for.
Im looking for R34 Replacements for a GTT to power a highflow so I dont really need a massive injector, I wont be running crazy boost so really only want to run a 555 or 700ish set incase I want to eventually update the R34 turbo.
Ive seen HKS, Nismo, Sard, Blitz and so on, is there really a difference in quality with those jap brands? Why is Sard more expensive than Nismo?
Finally what should I get? most people go with nismo from what I find any reason for that?
Thanks
https://www.sau.com.au/forums/topic/205679-whats-the-go-with-injectors/
  • Replies 42
No r33 are side feed, R34 are top feed
You can not use gtr or s15 injectors as suggested.
I have just fitted some blitz 525cc in my neo stagea. Have had it tuned 2 weeks ago with a power FC. Works great
$699 set from slide. I got mine thru greenline cost me under $600 del.
They come with new plugs, but they are not needed. I had to get new o rings from a mobile injector guy ($20 on a sunday) to suit the fuel rail. Pretty sure the 350z uses the same type of injector, that's why the plugs and the wrong o rings supplied with them. The injectors are approx 8mm longer than the standard ones and need to get the 2 supplied spacers from blitz which lifts the fuel rail up.
The nismo might be a better fit but cost $200 more.
Attached is a photo from yahoo auctions, which shows the alloy spacers and new o rings needed
Well ive investigated a few options, Seems Nismo only make a 480CC compatable with the ER34.
For my application of highflow turbo, perhaps at most 240-250rwkw would this be enough flow? I would assume so but need confirmation.
Ive also decided to bring in a HKS fuel pump capable of 250L a hour ( i read the same pump for a 240sx was rated at 165psi??), I would assume it would not suffer leaning out from higher boost PSI as its HKS (it is also direct drop in like tomei) can anyone confirm as I cannot find statistics on its claims (I would assume its underclaimed because its HKS)
My friend runs it on a R33 with no issues, anyone else?
Edited by DECIM8
Alright then, Seems greenline are the cheapest option but dont sell nismo.
Again ill just ask will 480cc be enough for my application? if stocks are handling 200kw I dont see why 480 wouldnt handle 250rwkw
check out Deatschwerks in the states
they may do topfeed Rb25det injectors
forget the dodgy secondhandies... if you really want redrilled injectors get em done locally for ALOT LESS.
IN r34 BLITZ or NISMO are the go .
The Deatschwerks ones are great i have been using them for about 1 year now with no problem what so ever. if they are put in the right way you will not have a problem. Another good thing is that the std ecu can run them as well.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
