  • Replies 70
I got my series 2 stagea stock as and was getting about 350ks a tank, so i had a carbon clean done on the fuel system cost me $120 and i was then getting 450km to 550km a tank then I had aftermarket ecu, intercooler, fuel pressure regulator, splitfire ignition coils, 3 inch mandrel turbo back exhaust, eboost2 running 14 psi, 500hp intank fuel pump, apexi power intake, and now i get around 300kms to 350kms a tank now I want to sell the beast.
hey ben you sound like your driving like your username suggests, but on a more serious note i hope your not running 14psi on a std turbo, and have you had the car tuned since doing mods, fuel usage is way to high , if your driving hard ok consumption is always gunna be shit, but with your mods and tuned properly you should be doing better than that,
anyway hope you sus it out rather than sell it,
goodluck leigh.
I just filled up 59.91lt to the brim, I had done 407k's and it works out to about 14.7/100k's after my first full tank on my stag (only just got it :nyaanyaa: )
thats with a bit of a lead foot throughout the whole tank.... :cheers:
my question is - when the empty light comes on - how many litres does that mean it has left in the tank??
when the empty light came on in my 34 i had 15lt left in the tank......
Edited by FULOCK
well then i must try and drive my car till it get really low. i have only ever been able to squze 55 lt into my car whenever i have filled it up and i normally have driven anywhere from 450 to just over 500 km when i fill up. it seems to me that there is still a fair bit of fuel left when the gauge reads empty.
FULOCK i usually always put fuel in once the light comes on and I always get 58L in... so if the tank is 68L (as said a couple of posts before yours :D) then you'd have 10 ltrs once the fuel light comes on.
Edited by StageaGirl
goodluck leigh.
Yeah had it tuned and yes i am running 14psi on standard turbo was told that was the maximum it could handle. I have wondered if I should take it to someone else to see if it has been tuned do you know of anyone i live on the gold coast
Hey buddy just reiterating what others have said.
14psi is what it takes to pretty much kill the turbo instantly. You'd want to step down from 14 a fair bit to make it safe enough to last.
I had mine on 11psi and I think you'll find most people on here keep it around 10-11psi with the stock turbo.
Replacing the turbo with something as good or better is going to be an expensive operation but you do have options and the cost varies from ~$1000 to ~$2500 depending on what you want...and the more expensive ones aren't always better. :P
Mine was averaging 13-14L/100km on the standard turbo (8psi) and 10L/100km on the highway.
Try to get it fixed a bit before selling it cos it will really harm your sale price if the fuel economy isn't great.
I have a M35 Stage and arount town I get about 14L / 100 and on the highway I average 10L / 100
I've done 2 full tanks in city driving (90% of the time just feathering the gas pedal). Both occasions have clocked 500kms which is about 6.25 kms per litre of fuel, or 16L/100kms.
For a later model engine, i think that's pretty pathetic. One of the reasons why I sold my R34 was to get something that gives you good mileage. It's certainly disappointed me so far..
Another note. Spoke to Tony from North Shore Prestige where I got the car from. He suggested a few things to increase economy.
- change plugs
- clean injectors (if they do need cleaning but unlikely he said)
- clean the afm
- get an ebc so you can wind down the boost to say 5 pounds when you dont need the power.
- dont drive with a heavy foot, which im not anyway.
- change plugs
- clean the afm
I am getting around 7.5km/litre around town and if I can get some highway driving in (M2 or M5) I am getting this up to 7.8 - 8.0. It is driving a bit like an old lady and not being in a hurry but even when pushing a bit harder I can still get 7.5. The difference seems to be if you can keep moving. The stop start traffic kills the economy.
Cheers
Andy
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
