Spotted a red commodore ute with an SAU sticker on it, around 12 going past TTP.......... is that still yours Matty 31??
nah glen, not mine anymore mate. still reppin the SAU stickers kinda scares me but LOL
new tow bitch is much better :O
yeah maybe the think the SAU = Sick Arse Ute :banana:
hahaha good one ;D
-D
EDIT: ironically that just reminded me of an ss commodore ute with the number plates 'uteruss'
i lawld.
Edited by Dohmar
Spotted Donnon leaving his place this morning in the 35 and I nearly shit myself :banana: There I was working away on the place next door, then I hear this car start up with a sweet idle, it got my interest so I peaked around the corner and there she was, in all her glory.
I don't car what anyone says, that car is sex on wheels!
Saw a black 32 gtr on the way back from Modbury around 1pm
Saw a police car follow me over the course of 6 backstreets about 20 minutes ago. They didn't pull me over tho, which was weird I thought *shrug* they were pretty close to me, thats for sure...
Either case, they kept going when I pulled into the hot dog shop at collinswood heh...
-D
got a wave from a black skyline the other night, i think it was last night? very vague i know, but if u own a black skyline and waved to a white 34, hey :blink:
Edited by Damo_R34
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
