Near the North East/Ascot Tce intersection :)
Hrm.... were u in the back seat and a couple of hot chicks were in the front?
If that be the case, Im sorry I didnt notice you. Your company was much more prettier :laugh:
-D
Edit
Is heslo not pretty enough?
Is his turbo broken?
Does he drift too much?
Is he defected often?
Does he get spotted much?
Edited by Dohmar
:laugh: No chickies I'm afraid, now that I think of it, I spotted you on the way home so I wasn't in my mates 200SX, I was driving my other mates R33 GTS-t. God DAMN! Bad memory! Nice homage to Kasey Chambers there... :)
To answer your questions... Upgrades :D
just seen a nice grey 33gtr turn off of kings rd onto bolivar rd.
also big thanx to RBR 033. thanx for cutting me off dickhead. just cause im in my daily turning around a roundabout you dont have to cut infront and make me slam on my brakes. lucky i didnt hit you in the f@#$n drivers door.
Hrm shit, u saw me again? Or u were driving the 33 the other day?
Yeah I hate kasey chambers like the french hate the english... every time I hear her on the radio, i change station (which is why I only can parody the first verse, buggered if i know what the rest is)
-D
hrm isnt that hillzy's car (RBR 033) ?
-D
No, I was driving the 33 the other day, just bad memory :laugh:
Hrm... in that case im even more confused, I usually notice all skylines on the road.... did ya stick yr hand out the window or was the window tinted? wouldnt have noticed a wave otherwise heh
-D
^^ lol we were driving 2 cars behind that yellow R34 down Grand Junction Road tonight in my wife's blue Honda Accord Euro. There was a noisy white S5 RX7 near us too
I'll claim the silver stag!! :wave:
Silver i said , not pearl white :( -unless you guys saw me in the laser ? :(
Spotted a idiot in a black R31 4 door with p plates driving like a tool up main north this arvo on way home from work.
:D
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
