Didn't see ya sorry ... plus I'm usually in my own little world going to work.
Paint job is coming, but I need to fix/replace my turbo first now :thumbsup:
I was sitting on Unley Rd about to cross onto Pultney St, a few cars back from the front so you wouldn't have been able to see my car :)
(besides i was in the SP23)
Dunno. :thumbsup: But I did get it second hand despite having it checked out by a local shop. Stag gets oil change every 5,000kms. I baby it around all the time, just cruising. Running under 10psi boost. Garrett core and all, never suffered any abuse. Developing a slight rattle/dry noise. No oil leak or smoke. Just slightly noisy at the moment. I'll know more after I've seen ATS ... but at this stage they might be rebuilding it for me. :)
hmmm i got a turbo here thats got problems too. seems all good and no smoke either till you get the boost up. think its bearings are shot as it makes a noise under boost and looses boost under top end revs. lucky i had another layin around i slapped on
not good and not happy.
spotted a grey 4 door 34 low n with p plates doing about 80 up brighton road at about 6 PM
SLOW DOWN W4NKER
Spot on Benzender I to have a R34 silver in colour and low , but that was not me you've seen but ive seen the the same car in the mornings speeding down brighton rd. wish the person doing it would stop it gives us all bad reputation and makes people think its me because we have the same car.
Finally spotted you nightcrawler.
going through a round about. heading into northgate. around 7pm. I was heading nth east straight through to Oakden.
Was right next to you. not sure if u saw me tho.
damn didn't see you mate ... I was bolting home and running late for dinner ;)
Whats happened to your turbz roo?
Today driving up the freeway to Mt Barker to work. Red VS Commie pulled up along side me sporting a SAU sticker on rear right window got a wave as he undertook me. I drive rather casually up to work in the morning if your wondering why i wasnt sitting on the speed limit lol. Who was it?
was it a ute with average paint and gay kit? sounds like my old ute
picture of it in its better days
spotted a silver r33 gtr on salisbury highway this morning
and a white stag somewhere cant remeber
and vange on prospect rd going home
i'll just claim that one ey ... i haven't been spotted in a while
Spotted a Deep Purple Legnum parked in front of my house last night with a Iron Chef Imports sticker on the back.
That's the 3rd car in my street with a ICI sticker on it! Kristian's consuming the street.
Also spotted a R33 GTR, Midnight Purple going down South road yesterday arvo.
Spotted to ugliest R32 at Westlakes today!
Silver, big chromies, some gay wing, black bonnet, chopped up front bar with massive front mount hanging out and a GTR badge on the front. f**k is was the gayest thing I've seen
lol yea ok i dont think anyone will know !!
you had a FAGadore ute matty??? ;)
you are now DISOWNED
+ 1
:P
also spotted my car at Claudes Trim Shop getting the boot finally finished..........wooT!!!!!!!!! :huh:
Spotted today on way home from work, an r33 orange with black roof and bonnet with a white r33 behind it waiting to turn right from waterloo corner road onto port wakefield road!
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
