Kristian are you in japan or back in adelaide
Back home, and itching to take the N1 for a squirt lol
I would say that is my wifes car good spoting was it the same as the one in my profile?
Yeah although I can't remember if it had the sunroof or not. If it is indeed you, you came right past my front door on Saturday night around midnight, followed by two idiots on a minibike lol... Spotted again on Wednesday on Grenfell Road.
Spotted a pretty schmick looking Silver R32 GTR turning onto Kingfisher Drive at Hewett. Just before 6.30pm Tuesday.
I recon I have seen the same one on redbanks road a few times at the roundabout. Very schmick I agree.
yes that was me. i remember those idiots on the mini bikes just after i left my mates place.
Spotted Sky Sky going along King William St yesterday afternoon
If you're on here, I'd get that smoke fixed when you were idling. It was puffing out a bit of white/grey smoke.
thanx mate... but i just went outside and ran car for 5 mins and didnt see any smoke comming out of exhaust. i'll still take a better look at it later :)
btw, you mispelled my plates, but so do all the other people including old grannies calling up cops about "hoons" lol  :P
Edited by Rocky88
Spotted SLY at about 2:30 going down McIntyre Rd. Was in my work ute but gave ya a thumbs up anyway. I think you saw me from the little squirt you gave it :P
Spotted the same car about a minute ahead of you, on Golden Way lol. Nearly ran into the kerb perving on it!! Soooo sexy!
Oh lol sorry, it's sxy sky! I was half asleep when I wrote that.
Yeah, nice car, though! Yeah it was only a 10 second puff of smoke that came out... it wasn't billowing out lol so nothing to worry about I guess. It didn't happen when you took off, either.
spotted what I think was JACK 88 in seaford. on south rd, I was to busy cussing the trucks blocking up both lanes to wave..lol
spotted aberax R33 and his boss's stag, as well as a silver stag near maccas noarlunga.
a nice RX8 in bayside blue or similar aftermarket paint and bronze volks near the cop shop at christies beach, looked nice with colours like that..
and a undercover cop/detective wearing what looked like a bright red or hot pink flowered shirt and magnum PI sunnies..lol who needs cop logos when your shirt is that loud..lol
You go to Super Cheap? :)
Trying to better the Silvia :P
at least *I* shop at repco. :P
the super cheap and the repco are next to each other...
well the repco closed its doors at 5.30 for some reason...........dont understand y it was a thirsday night!!
and i only needed cable ties anyway...
That other silver stag you saw is a friend of the boss. I think its a manual stag too.
spotted a comic thing today, a R31 Aussie, with cardboard headlights,, yes it had cardboard cutouts over the factory ones to make it look like the jap ones for R31's with projector beams.. it had some other interesting mods, but I was trying to find the camera before it took off..lol
defect on wheels
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
