Not sure if it was there or not Talbo - my eyes hurt too much from looking at the Supra .... I even think the leatherette seat covers had been spray-painted - as the centres were metallic silver, and I have never seen material like it .... ewwwwwwwwwwwwwwwwwwwwwwww
Spotted two silver stags together this afternoon near the Bridgestone factory on south road, first one had gold rims, the second had 260rs plates.
Also spotted a girl driving a black 33 gtr near harvey norman on marion rd, had a vented bonnet and d wing.
seen that on magill rd tonight,recently sold by viva,lucky new owner..
Mate bought it, has some plans for it, I wont spoil his fun by divulging them here we will just have to wait and see...
Spotted a pinky/salmon coloured r34, with chromies and a bodykit similar to the one featured on the r34 in the Fast and the Furious 2 on Main South road about 8.30am.
Spotted PRIME 34, white r34 GT-T, wheels, bodykit, transformer sticker on the boot on Glen Osmond about 3.30pm
Haha saw that one yesterday too Andrew...., Is the 33 with commo spec rims still in that same yard?
Nah some poor bugger bought it, seen it twice this week around mawsonlakes in the morning bout 6am.
Spotted a two tone 33, plates JASVIN. in behind the Zoo. 32 sedan on hackney rd, pretty stock looking. Black Stagea at Glenside, Silver Stag at Bunnings Parafield just after 5pm. Blue 34 GTR behind Bunnings and Chris (zirtytwo) picking up the exhaust wrap. Yellow 34 on Elizabeth way around 7:30pm plates HSVEATR. A KE70 painted up like a AE86 panda pack too.
spotted a gay spec r33 in silver, with 20" pizza pan wheels in chrome and white wall tires at grand auto wreckers :verymad:
another r33 in silver, fresh to the wreckers if your boys need parts it had heaps.... not dented up to bad
black r33 with no wing on north rd at a car yard, looked like craigs old car ?
That would be myself and Cheffstag coming home from helping tangles finish of the new turbo install :verymad:
That would be myself and Cheffstag coming home from helping tangles finish of the new turbo install :)
did u also spot the north adelaide spec mum in her sugar daddys lexus rx330 on the fone, tail gating and beeping...wondering y i was going slow for her? any way :sick: lol....
spotted a white 35gtr on hutt st, cc plates... boosted it a bit for us, sounded very very nice
haha yea i noticed it the other day... god its ugly. the Green 33 went about a week or so ago. i work really close to this car yard and see all the comings and goings.
keep seeing a black (?) R34 behind the gg village, looks nice.
IIRC they wanted like 20K for it too.....WTF!
Spotted a 32 gtr at ultratune at melrose park, had something similar to godzilla on its plates.
That would be myself and Cheffstag coming home from helping tangles finish of the new turbo install >_<
You were most probably on your way to his place, since you were heading south. It was just after 3pm.
stupidly dangerous, but still...
just spotted a GTiR pulsar throw an epic scando from my street into the lane opposite my place, was really well done... but yeah... stupid...
(but awesome to watch)
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
