Did he take the time to take you for a drive in it as well?
Yeah, he did.
went to the Forbes shopping centre. Dave made a comment about how i drive an auto with a spool, and the asian guy behind the counter even laughed at me! :D
Haha thanks!
Do you live around that area? I live up near st agnes.
Someone down the street from me has a black s1 r33.
See it parked outside nearly everyday lol
I used to live at Hope Valley, now I live out in whoop whoop lol
Spotted Daves S14.
Even got a ride in it.
Do like muchly. :)
Yeah, he did.
went to the Forbes shopping centre. Dave made a comment about how i drive an auto with a spool, and the asian guy behind the counter even laughed at me! :(
You missed the joke there... by a mile
Yeah, i really didn't see the joke there..
Sigh, no matter, Dave will
BAH! i just read what you meant.
*shakes head* minds of today :D
I here-by dub thee, Captain Slow :D
f**kin lol! :D
spotted twink and many other from the 31 club today, took a few of em for a spin, had one screaming about how she was gonna die. good times.
Edited by scandyflick
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
