Spotted (probably the toughest I've seen) white 33 GTR yesterday on NE Rd, near Plaza Holden at around 3pm ish. Haven't seen this car or pics of it before. Had Tomei deacl on front fender or door.
That would be Vince's, he has an RB29 under the bonnet too :down:
Christies downs you say.... Where's that :)
Down south :down: dw they were prolly salisbury scum coming to you to see what they can steal
nah christies is worse than salisbury.
southern bogans have made us northerners look placid and well mannered :)
Saw you too bud! Yeah I'm a huge fan of the sound too, AM Performance strikes again :):down:
hahah yep sure does.... picked up mine from him on sat... its a lot louder than i thought it would be but the work is amazing...
also spotted a silver 33 on the grove way by the bp about 15 mins ago
Yeah I saw your car in there while he was working on it. Definitely came up nice!
Spotted a few old school cars and a ute all with hydrolics last night on Rundle St. Put on a real good show at the lights hahaha
if you seen an old white 57 chev that was me and my new wife in the back. we had our wedding that day and went down rundle st that night on the way to our hotel.
seen in auckland yesterday a crap load of legnums, a s1 stag, a r33 4dr with a taxi sign on it and yes! 2 r34 vspec2 in the same driveway. thats right 2!
im in canada now for 3 weeks and im yet to see anything good besides alot of dodge and chev suv.
You clearly don't live South, then.
lets just say, both suck and the remnant overflow ended up in the middle of town..lol
really the stupid crime here in adelaide is rampant, graffitti, car theft,robbery, break ins.
you need a "make my day law" and a legal system with teeth for crims
found two piles of tools the crim was trying to use for slim jim the door open, the alarm saved it both times before damage was done. persistant pricks , next time they get a bigger suprise then a siren,
same car was attempted carjacked in front of Christies beach cop shop in maccas car park. about 10pm one night by 10-12yr olds, got in the car and demanded her to get out. ???? WTF savages
road kill is common in canada.lol so are pickup trucks and paddock bashers
hitting a moose in a skyline wouldn't be a good thing, hence the pick up trucks. go to Billings Montana to see lots of hotted up cars. and women ....not far from Canadian rockies
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
