spotted a tough black 33 (gtr?) with white TE37's on waterloo cnr road, bout 5:30 today.
also spotted a stag with black r34 gtt rims on saturday somewhere between salisbury and payneham :P
lastly, a stag with lenso D1R's in the moonta carpark, big YP car club sticker.
Just spotted a bright yellow 180sx with black bonnet go through my circuit....looked like he slowed down to look at my car... and then speed off as fast as he could doing drifts around the next corner????? WTF!!!!!!!!!!!
Anyone know who this is?
spotted a black s15 on 20's (yeah, i know) getting a solid going over by 3 cops at gepps cross a little before 6.
and saw krish, mitch, and marko at vilis.
yup. :D
what where you in/where were you?
Was in my dad's outlander so wouldn't have spotted me, was on elizabeth way there near the ford dealership!!
Toughhhhh guyyy!
Keep seeing a silver R34 with custom plates black on silver something along the lines of r34 sky or something.... Another cock of a skyline owner, chirping and boosting every time i see him...
Saw shy033 last night on my way to work. Take off from the lights was a bit noisy with ya wheels squealing for ages, wasnt sure if it was you or the silvia behind you that came from nowhere.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
