Spotted a white 31, Flaxmil road, about half hour ago. Had R31 skyline club stickers on the side windows and one about a cake? on the rear window lol Think it had P plates..
Also a black 34 2dr going along panatalinga road heading north, just off wheatshief road.. This was about half hour ago also..
thats linda's car.....sticker would have been "to make room for cupcake"
Thats the one lol thought it was funny. Was going to wave or say hi to him but may have been weird coming from a guy in a VL wagon...
Oh and also saw a white stag reversed parked outside of exhaust tech. On goodwood road. Had S series plates, looks fairly nice.
nope, not me. was at work way down the dirty south
spotted a silver 33R with black rims on Salisbury Hwy last nite bout 11........nice flames :D
saw abe go past AGAIN this morning :bunny:
What did i do this time?...you may see me again tomorrow if your there...unless i take a different route :blush:
Spotted a Silver R32 on Marion Road at about 5:45pm.
What did i do this time?...you may see me again tomorrow if your there...unless i take a different route :D
nothing this time, drove past while i was winching cable thru the conduits, still could hear u over the diesel winch motor LOL. i'll be there for a few weeks as we're doin all the underground cable for the junction revamp
Spotted blue r33 on bridge road 1 hour ago sliding in the rain.
were you driving at the back of pt adel about 15 min ago?
spotted 2 prostitutes on hanson rd
spotted a hot house green and primer celica on hanson rd sporting a "turbo tosser" sticker
spotted R33 dark grey on victoria rd
and this is all in my adventure to croydon maccas lol
:down:
Nope i wasnt in pt adelaide that day lol. ahaha 2 prostitute lol, i always see prostitute on hanson road, mostly ferral looking ones, and always on grand junction road but there bogans. :down:
Hmm, I never see prostitutes on Hanson Road, maybe they're running away from me...
Anyway, I think I saw James34 on Main North Road, Enfield at around midnight tonight, heading to town.
Lol mayb u cant tell which one are the prosties on hanson road haha, well they usually look feral and junkies that always carry hand bags and some are abo's.
Spotted in Walkley Heights yesterday a white 34 and spotted 2 mins ago out my window a silver 34 driving around around in Walkley's.
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
