Turbo MX-5 most days on Victoria Rd after 3pm. Looks like the one that has been to SAU track day a few times.
Yeah that's Glenn, feel free to give him the finger. I want to see if he mentions something to me about it :laugh:
there are 2 red mx5 turbo's getting around Adelaide :blink:
and both from north east :D
theres actually 3 now, there's one from down south, but that has Reynella mazda stickers on the doors
Black 34 turning onto Hartley rd at some ungodly hour this morning. Waved but the driver was obviously still asleep haha
I'm guessing that was me. Early in the morn, Thought I may have seen a wave.
Spotted dohmar a few days ago, heading onto some road of mullers.
Have you got a deleted spoiler? If so I see you around a bit, was driving behind you on Hartley road the other day.
Will do. Probably be on Eastern Pde. Green VY SS ute or white Grand Vitara. Each day I'll change it up.
Spotted blue r34 gtr at dans murphy today at 4 ish and a orange 33 leaving the lights on main north road not long ago and a corrola try to drag it following by 2 soarers. plates of the 33 were flylice
Spotted a yellow 32 yesterday arvo with SKY 320 on the plates, nice clean looking car, blonde chick driving it.. Heading south along South Road & Panatalinga Road..
Also a black 34 with straight pipes coming out of Meadows onto Adelaide to V/H Road, could have been the same one with LED tail lights I spotted awhile ago...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
