So i need to replace the gaskets on my TD-06 L2 20g to finish off the rebuild on my RB20.
Im having trouble finding anyone that stocks or can get a hold of the gaskets and just wondering if anyone has replaced theres before and who did they go through???
I need:
manifold
manifold to turbo
turbo to dump
Any help appreciated
Cheers Ben
PS: i know this is now in 2 sections but had no replies so far and i know guys like Troy, James and Silvergtst are running the same turbo :D
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/
I had the biggest prick of the time trying to find a manifold to head gasket to suit RB20/25.
I have the part number and called NISSAN and they want between $103 - $115 which I thought was a rip off so ended up ordering it through RHD JAPAN.
About $71 incl air mail express delivery to my door, which is pretty good considering the prices here.
Part #14036-21U00
https://www.rhdjapan.com/home/products/prod...roduct_id=3277#
As for the other gasket any good local exhaust shop should have them.
Good luck.
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3647717
i got a few, i found :ninja:
sorry bout other day comp dropped out :(
email me your addy and i will arrange to send them $30 for the two trust ones. Call MD Spares in moorabin for your head to manifold gasket.
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3649419
i got a few, i found :(
sorry bout other day comp dropped out ;)
Email sent :ninja:
Will get onto MD Spares on Monday
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3649774
  • 1 month later...
Autobarn....that's where I got my ones
Hey Dan
my local Autobarn couldn't help me as "i" didn't have the part numbers, as you would see Trent replied last month about having them but i haven't heard back since transferring the money so the search continues so i can finish the car.
I will call a couple of the AB stores in Melbourne/Sydney tomorrow and see if they are able to help out further.
Cheers Ben
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3759142
GCG have the gaskets... call them..not cheap though.. i think around the $50 mark for a dump gasket... you can use ur old one with some glue... or ifyour flanges are real smoothe and rust free just use exhuast seals and no gasket...
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3759523
Hey Dan
Cheers Ben
WTF????? i have not recieved your money and we even called and SMS'd to see if you still wanted them, with no reply................... they are still here waiting in the same spot.
I take offense to the above greatly. If you have proof of transfer (im assuming wrong acc) let me know or at least call me 0419 590220 if there was a problem
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3760565
WHAT????? i have not recieved your money and you did not reply to CATS calls or SMS................... they are still here waiting.
Transfered 29/2/08 01:27:19 pm, receipt number: N022986488721
I replied to the sms and also sent you a couple of emails but didn't hear anything :( .
Just checked again and the account details are correct (from sms) so you should of received it, no biggy though i just need the gaskets to finish the car hence trying to source them elsewhere.
Not having ago at you or Cat just want to finish the car Trent and figured you guys have been busy :(
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3760590
I think you should send the Pringles as well, a show of good faith
No need for good faith, just some crossed wires so it looks :rant:
BUT i do have the munchies a little after finishing work and some pringles would go down a treat :)
https://www.sau.com.au/forums/topic/206143-turbo-gaskets/#findComment-3764237
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
