  • Replies 40
Trent, what Toyo tyres were on the S13 that Baron purchased. He was kind enough to give me a steer at PI and the tyres put up with about 5-6 laps and were still way better then i expected.
PS...hats off to the way that car is screwed together. Its a great car! :)
Have you thought about kumho Ecsta SPT's
im currently running them and loving them
much better then the Bridgy G3s
if you interested i can take you for a spin in my car?
I'll have a ask around about them.
No need for a spin but thanks. :)
what do you want to know?
Are the extra $$ really worth it?
I hardly ever push the car to its cornering limits so really what I want to know is are the T1Rs noticeably better for straight line acceleration grip or are the benefits primarily with cornering?
troy, the proxes 4 are on the silvia, and yeah they are not too bad at all. I'm not really used to using street tyres on the track, but they held up well to 120kms of phillip island. then another 1000+ freeway kms home. they aren't noisy. I wouldn't say they are super grippy, but they are a road tyre after all, and on the road they are pretty decent. :)
Yep, picked it up friday night then drove it at Phillip Island on saturday. tough track! Car held up well, driver it has to be said was pretty average after 4 hours sleep friday night ;) awesome track though. very, very different to anything we have in NSW. maybe we can run in your R35 around there... :):D:P
Just got back to sydney an hour ago.
Hey ppls,
I'm up for a set of tyres.
Is there any one who has ran both the Toyo T1r and Proxes 4?
Probably won't get too many replies but.....
So are you running the Proxes 4 at the moment? Have you been happy with them? Im thinking about getting them for my street rims. People know what the common asking price is for them in the 235/40/17 range?
what was the car that you bought richard? what were the mods?
well I don't want to whore up the thread too much, but I did at least give one helpful reply!
I bought an S13 silvia. quite a few mods. but some of the main ones: SR20, 2 way lsd, Trust T518Z, stainless mani, Blitz/ORC clutch, PFC, 550injectors, Z32 AFM, S14 box, coil-overs, 5 stud conversion, R33 brakes, FMIC, trust exhaust, Uras N+ kit etc. took it to phillip island on the weekend. and I will see you at some drift practice soon! seems all the cool kids are doing it, and you can show me how! I'm novice. :)
Well, i've got the T1R's, only in 205/55/R16 so they're not very big. Ummm they've been pretty good, Awesome traction for a road tyre. The Proxes 4's were $10 cheaper than the T1R's in the same size at the time i bought mine.
There's some drifters in the Toyo drift series using the proxes 4's to drift on. The twin turboed LS1 R34 (the red one, i can't remember the team name or driver) uses them. Apparently they're quite consistent when used for drifting and when the tread wears down. As for street use, ican't comment on that. But it can't be bad.
I figured for myslef, why not get toyo's flagship tyre for just the few extra $$. Well it was only $10 per tyre for me at the time. Plus the wet weather grip was unbelievable. I've got the usual 190-200rwkw, on a soaked wet bituman(not even hot mix) on a standard take off not dumping the clutch, it would grip under full acceleration and not even lose traction on gear changes. Pretty good in my books. Great aquaplaning resistance too.
One thing i did notice, as soon as i got them on the car, in just regular driving and harder driving (twisties) you could feel that the tread was quite soft and there was a quite noticable extra amount of side to side movement in the tread. But this icky feeling soon dissappeared after a couple of weeks and some driving on them.
So thats all the experience i have to offer.
Edited by KeyMaker
No unfortunately not. :D
I went with the suspension + reasonable tyres + ebc + cams + new steer rack and a few other bits route instead.
Otherwise it would have been only wheels and tyres which I would not have enjoyed anywhere near as much.
So far the short 20km drive quite happy with the Proxes 4. Nice and grippy in a straight line. They have 2x the straight line grip of a near new 245/40/18 nankang NS2.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
