hi guys,
I recently have spun a big end bearing and i just want to know how to help prevent it from happening again.
These were the mods when it happened:-
ACL race bearings
N1 oil pump
blueprinted bottom end
Castrol 5w-30
Is there anything i should do or is it just bad luck/motor not put together probably
cheers Tom
https://www.sau.com.au/forums/topic/206613-r33-gtr/
  • Replies 49
Getting a baffled sump will only help with keeping your oil cooler (but upgrading to an aftermarket sump will generally mean higher capacity which is a good thing) and your problem has stemmed from lack of oil.
The simple fix is to overfill your oil 500ml - 1L above the full marker but this is generally just a precaution for track going vehicles.
considering your car is street only id be wondering if there was some sort of blockage or your oil pump failure. This really shouldn't occur on a street only car.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655137
Sorry, but you have missed the point of having a baffled sump - The point of the baffles isn't to keep your oil cooler, but rather to prevent oil starvation under hard cornering/load, which is particularly common at the track.
Ideally, anyone building an engine should be at a minimum fitting sump baffles, a good quality oil cooler, and an upper oil gallery restrictor.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655278
what oil should i be using to help prevent this happening again??? also would keeping the oil cooler help. what temperature should it be at??
Yes, keeping the oil cool is a priority.
Which oil you choose depends on your engine and its condition.
If the oil gets too hot, it gets too thin and you will run the risk of spinning a bearing again.
Personally I run Motul 300V Chrono, however given that my GTR takes 10 litres per change with my larger sump and cooler setup, it makes for expensive oil changes!
An oil cooler really is a must have on a modified GTR.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655326
IMO - Baffles - waste of money as its only fixing another problem indirectly.
For a street GTR, with the RIGHT head modifications to stop the oil starvation in the first place... negates the need for a sump.
Heavily tracked GTR's here (350rwkw style) ran stock sumps without problem, so can you for a street car :)
Read the FI Guide (its a sticky), and in there it contains a link for Oil Control in RB's.
If you get that right, and have it rebuilt correctly, there is no reason it should die.
I would say your motor either wasn't assembled correctly or you ran low on oil at some point possibly. Likely bet is motor assembly.
Castrol 10/60 is what i would be using in a built motor personally, been run in all of mine for the past 4 years, no issues
5/30 is probably part of the issue
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655372
what power are you putting out?? what rods are you using? what rod bolts/studs are you using??
pushing big hp on stock rod bolts "can" stretch and lead to big end failures, although oil control problem are common in gtr's as stated
A spun bigend on a 20k km built engine driven on the street = something very very wrong
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655410
Detonation/pre-ignition is probably the biggest killer of conrod bearings on GTR's when the boost is wound up. Most of the time you'll find there's no oil pump problem etc.. Have a look at the other conrod bearings, if they have marking on the upper bearing from 10 thru 1 o-clock it's usually a good sign of detonation. It happens because the mixture fires too early and the piston is pushed back down the bore while the crank is still trying to push it up, this squeezes out the oil film and you have metal on metal contact between the crank journal and the bearing.
https://www.sau.com.au/forums/topic/206613-r33-gtr/#findComment-3655710
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
