  • Replies 62
very nice results mate looks like it would be very quick on the street, looking at a similar package as yours, got the microtech and everything else, just dunno which turbo as yet but i'm after sumthing fun to drive on the street and the gt-rs certainly looks fun,
does anyone know of a decent tuner of microtech in brisbane, because everyone i talk to regards them as being a bit rough, but obviously it comes down to the tuner, just trying to find one who specialises in them at the moment.
Nice result! cant wait to get mine tuned :D, only 25days away lol
What fuel? and are you still using the stock dump and front pipes or after market?
Just on BP 98 Octane, wish we had some of that 100 Shell fuel up here :/
Yeah aftermarket all in one bellmouth 3" dump pipe.
You'll love it man, IMO its probably one of the best sized turbos you can go on a RB25 with getting good power out of it and being very responsive at the same time. Very good street driving.
Here's mine...
dangerman, you're an idiot :ermm:
for starters you can't even see how much power its making at 60km/h, and even if you could I doubt the postie bike makes anywhere near that.
Thats also where the graph starts, which means thats where the tuner accelerated...before that he was cruising in 4th gear. Well done, moron :D
is that cos its microtech or cos its map sensor thats its poo ?
map sensor is fine
it doesnt have idle up when cold, so it makes it hard to tune when its dead cold, but with abit of time you can get it so its perfect.
map sensor is fine
how long did it take him to tune start to finish? Also what did your tuner do about knock? or did he just stay conservative enough not to have to worry about it?
He listened for knock electronically (not sure the exact name of the machine they use, im sure someone here knows though), and there was no knock. The tune was done safe to accomodate for hot days up here.
Well he had it for 2 days just so he could get it right and i told him he could have it for as long as he wanted, he also road tuned it to get it driving perfect and spent a few hours on idle alone to get it perfect. He went out of his way to make me happy with it and he succeded greatly. Only person i will use in Townsville now for any work that i can't do myself.
F@#* dangerman that just shit comment but that's my opinion.
any way i found my last dyno with my torque level, id like to see a post bike like this,even some larger turbos don't make torque like this...
Edited by WARLORD
Just on BP 98 Octane, wish we had some of that 100 Shell fuel up here :)
Hehe i dont have a gt-rs, that was my orignal choice and i was dead set on it after reading what everyone thought about them, but after doing hours of research it seemed the hks 3037 pro s was the better overall option, so thats what i went for :D , my aim is 270-280rwkw with a nice safe tune, only downside is im going to be running 95octane (all we have in my town which sucks) so i might need a little bit over 1bar to make that power, should be perfect for the street/track in my opinion.
Anyway awsome result man!:D
I really dont know how much to read into torque
This was my readout with standard everything really
it is an auto and in second gear i think that make abit of a difference with gear ratios etc ( not sure the exact ratio of 2nd compared to a manual in 3rd gear)
Hmm something dodge with that torque readout. Maybe some others more knowledge than I can explain how it could read that. Maybe the one above is also subject to discrepancy via how its measured... but stock doing 800Nm is a 'off' looking lol Also... you're power looks insanely high for a stock GTT/GTST type engine. Aren't dyno runs usually done in 4th or 3rd? Don't recall seeing one in 2nd before.
Maybe this is why my mechanic said he doesn't usually bother measuring torque cos it depends on the dyno setup too heavily? or how its used... or something
Edited by sl33py
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
