im seriously considering going an RB30det.... i need someone on her to tell me its a good idea to go and blow some money on doing it.
Basically ive got an RB25det atm with a GT3071R making 265 rwkw on 16 psi or 1.1-1.2 bar ive got cams coming to improve the lowdown (i dont run VCT atm) and the car is used for drift which isnt all about peak power.
I am getting my hands on a spare 25det head and RB30 block. My plans for the block were to put ACL rings, brearings and so forth in it, freshen it up, 25det oil pump with the crank mod to give more drive area. once this was done i was going to put the 25 head on it with a stock nissan HG and my 254 8.9mm lift cams the aim of the game is to keep it simple and reliable... I do not plan on making much more peak power then i am now (FWIW i made 282 rwkw on my 3071r on 20 psi) but what i do want is a HUGE midrange and instant responce.
am i on the right track or should i just stick to the 25?
Im a mechanic, so will be getting parts on the cheap and building the bottom end myself. the cost all up for the upgrade is budgeted at around $1000. Thats 2-300 for the crank mod (would get someone to do that for me) then 500 for ACL race bearings, ACL rings, gasket kit, front and rear mains seals, and head studs.
discuss.
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/
  • Replies 72
What pistons do you plan to run, and what static compression ratio?
Also what sort of rpm ceiling?
I may be slightly wide of the mark, but it seems that mild 30DET builds often produce similar maximum power figures to the donor 25DET, but at lower rpm. Their advantage is in torque, and with your spec 3071, I would say rapid response. Bigger torque would turn tyres easier, but is there any problem if you run out of revs?
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3657896
7500 is the current RPM limit... i would prob drop this back to 7000 for a 30DET in the aim of reliability. the fact that the 30det will make more torque earlier, and hopefully for longer means that if i do start to run out of revs all i need to do is shift up a gear.
As for pistons... i plan on stockers... unless someone suggests other wise... basically im just after a mild package. i really dont see myself going for a 400 rwkw package, All i want is to make the same peak power or maybe 10-20 rwkw more. but with a shitload more responce and torque throughout the revrange.
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3657954
i think joels is a larger turbo then mine.. but thats a moot point really.
one other thing, should i use a 25 or 26 oil pump?
Also, with the 25 head, i dont plan on running the VCT at all so its operation isnt needed, Do i still need to weld up the feed for it? or is there a way around it? If welding it up is the only way what is the correct way to go about it?
Edited by Simon-R32
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658376
drill it out - tap it and usea grub screw - that way if ever you go back to rb25 or sell off the head it can still be used.
also no need to redeck the head - unless your doing that already
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658498
run into issues with vct and these engine builds dont you?? something about where the added tensioner goes? or a oil gallery? il have to check again, but everyone says "dont use vct"... id also like a deffinate answer if anyone knows?? :P
CJ
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658554
im also thinking a 3L bottem end if mine decides to shit bricks. But on the other hand thinking of prepping a 26 crank, getting steel rods, and boring my engine out to a 2.7ltr with a 9,000rpm limiter :P 25psi on the 3540 and hks cams.
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658583
Do it
Use a decent oil pump though if you plan on smacking the limiter a lot - get a JUN one :P
If you dont like it, refit the old RB25 with fresh rings (and whatever else)
Read the RB30 results thread, there are some big numbers in there for even stock 3L bottom ends
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658706
thanks guys, yeah i have read through the RB30 thread, theres some 400 very informative pages but it makes finding what you want to know very hard lol. very impressive power figures being made too.
the grub screw idea sounds great, easy as pie too.
i dont want to run VCT since i have an RB20ecu remapped to run the 25 atm, no VCT control... besides ive got some cams coming anyway so i dont really need the VCT. if its less hassle i def wont bother rigging it up.
https://www.sau.com.au/forums/topic/206794-to-rb30-or-not/#findComment-3658804
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
