hey all i have noticed that united petrol station have a 98 pump these days. i have not tried it but has any one and is there any way to no whether its actually 98 octane. its seems to cheap compared to bp to be true. i saw it yesturday at $1.35 a litre. thats a saving of about 15cents.
am i right in saying that my car would knock more if i put it in (as its tuned on BP 98) if it wasnt 98 octane??? just monitor it on pfc hand controller. how ever dont really want my engine being the test unit.
might google it
https://www.sau.com.au/forums/topic/206967-united-petrol-stations/
Always rumours that even though it's 98 its still going to be different to BP 98, which is what most cars (with a/m computers) are tuned to in WA. Also, always rumours of people filling up with caltex 98 & getting a knock reading every now and then. Then, always rumous of people filling up with caltex 98 & not having any sort of change at all.
ive always used bp ultimate in mine and nothing else since import. Don think i will be changing now.. even tho 10 cents or so a litre cheaper is tempting. :D .. But the sky comes first so i think i will just pay it..
Maybe if you want give it a go, fill up half a tank and see how it goes... if it runs crap then u can fill up the other half with bp ultimate and hopefully that can improve it enough till it uses it all up? ..
I know some skylines that run on Shell 95... and they seem to run ok... but for a ~10cents less a litre... is it really worth it? When the damage bill can be much higher... :P
I put some in my tank last night 134c/L car seams to be running perfectly fine will give it a thrashing tonight and see if she blows
Let me know how it runs dude. Atm I'll willing to pay 10cents extra if it betters the car in the long run though. Plus I dont think Rocko has a United servo.
I usually run mine on Caltex 98 or BP98, only had bad fuel once when the caltex had almost run out (stupid me for filling up). Have also filled up with peak 98 and not had any troubles, but I will continue to fill up from caltex cos there's 3 of them within 5 mins of me and I have a fuel card. Filling up with std unleaded or 95 isn't really worth risking or hurting ur car with.
I dont get a choice . . in karratha we have a BP but they dont have 98 . . the highest is premium . . and when i asked if they had 98 they didnt even know what it was??? RETARDS!!! So i have to use premium
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
