Autocar Review. Gt-r Vs The M3 Vs Gt3
This is probably the best and honest review so far.
Everyone has a cry and says the GT3 is a better competitor to the GT-R then the 911TT. Well here's a test between them.
Part 1. http://www.autocar.co.uk/VideosWallpapers/...231443&CT=V
Part 2. http://www.autocar.co.uk/VideosWallpapers/...231444&CT=V
Thanks for posting those links.
Absolutely great to watch and just unbelievable to see what the R35 GTR is capable of. This is a truely amazing car.
I love his quote about it being 'a mini Veyron'.
Cheers.
Nissan dropped the 'Skyline' tag, as Inifinity now use it for their coupes and sedans...
Nissan confirmed that the R35 is simply, the Nissan GTR...
Actually it's spelt Infiniti and they do not use the Skyline badge at all. The Infinitis are G35 and G37's. The Skyline is alive and well though in Japan with the new V36's.
makes me wonder about the tunning industry and what they can get out the the vr38, cant wait till it gets released here in AUS, by then the jap would have very nice parts ready for us :banana:
"make me wonder why i bought the M3" LOL with reviews like this im sure poka's and bemmers will be more extreme in the future. f**k the worlds oil supply, we are going to have a "BIG automotive" world war
Edited by philta
wow... 3.8 60's with a piss weak lauch and two people in the car must be around 1850 or more of weight that the 3.8 TT is hammering to those speeds.
one word impressive
I like how he kept saying 'real world performance' to refer to his way of testing also :banana:
Lets face it, as far as Nissans go the GTR badge will always be associated with the Skyline brand.
...........for a company that used to be called DATSUN.........and its now making cars that is as good as a 911 Porka.........
CLASSIC
Yeah, how narrow minded are these car jurno's hey... what a tool.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
