Radiator Air Deflectors, New Group Buy (no 5)
  • Replies 113
so whats the go bud
how much for postage to Adelaide 5013
but the colour i want is Black please.
Cheers
Allan.M
yeah decided to not go the black powder coat i'll go just the plain alloy look.
cheers
Allan.M
i will take a S1 r33 in black.
First post updated
you have put me down in the first post as bare, wanted powder coated.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
