Radiator Air Deflectors, New Group Buy (no 5)
I'm interested, but in the middle of a GTR front end conversion for my R34 GTT... What are my options then chief???
  • Replies 113
HEy all.
Current list looks like this..
STAGEA Series I
Xmetal
STAGEA Series II
None
R33 Series I
_Scotty_ (Bare)
rd-runr (Bare)
Scadtional
H@ME
reflexman
Krishy
Dan_AE86
R33 Series II
SkyKC
bnew
Silver_R34_GT-T (Bare)
Rhinorebel (Bare)
cjpwrx
t.head_wood
STRYKR 33
sfrizza
typevu
ToMMaH
GtstCoupe
Pauly33GTS-t
bryno
inthisglass
R33 GTR Series III
None
R34 GT-T STD BAR
mr_tea_pot
Hopeyz
yld34t
jrm
fishy
Howie
uncouth32
putraged
viet_boi
jeffboyracer
R34 GT-T Nismo Bar / Series II
Magic
lastarfighta
wisey18
charlie22
R34 GT-T Aftermarket bar
Icy
Thanks for the update bass junky.
Just a correction... mine is a R34 GT-T Nismo Bar not a R34 GT-T STD BAR.
Cheers again.
Inline with GB rules about having a start & end date - this is now closed.
http://www.skylinesaustralia.com/forums/Th...Gro-t81129.html
SAU is clamping down on these GB's that never occur, never end, and so on.
PM me if you have a problem. However, before you PM me think about this.
A group buy, is a group of people buying the product together to lower the price.
Buying single units here and there is not what constitutes a GROUP BUY
Thanks
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
