hey guys im about to put my motor back into my r32 gtr,
i took the box and motor out together but i have to remove the steering rack to get it out,
is their a way to put them back into gether without taking the steering rack off??
iv heard if people putting the motor and box from underneath the car, im not exactly sure on how to do this.
thx guys
https://www.sau.com.au/forums/topic/208557-rb26-removal-with-box-attatched/
to put it in form underneath remove the whole subframe then put the motor and box onto it (do up engine mounts etc). they lower car back onto subframe, bolt subframe back into chasis and voila you are done
well we've tried every way we can think of including from underneath and now always put it in thru the top. we don't have a hoist just a jack and engine hoist
but engine with box attached is a pain too, all we did was bend the radiator cross member. wrxhoon tells me it can be done though :D
Through the top I put them in seperately its easyer but you need experiance getting gearbox in but I can do it in about 2hrs this way (only bolted in not hooked up) if you have a hoist drop the subframe. undo the hicas crap lines etc undo coupling from steering col-rack, remove you waistegate actuators, put motor and box onto crossmember bolt up mounts,drive shaft/axles, use 2 gearbox lifts 1 under crossmember 1 under gearbox raise up slowly bolt up. I looked at doing it from top box attached and it look like a world of hurt to me. But if you try it let us know how you go. if you need more advice pm me.
I can only speak for a 33 GTR but you can get the engine and box in together going over the top.
You need to make sure you have a chain block close coupled (don't just try and use the engine lifter) and fit a come-along or similar with a soft sling around the gearbox to allow you to tilt it as required.
It is definitely not a one man job but can be done with some help (mine went in and out about 4 times making sure the custom top pipes fitted).
Cheers
I have alwys done it:
Box from under the car.. attach cross member..
Put engine cross member, steering rack, engine mounts and then drop engine in from the top..
Sometimes you will need to wobble a few things around (depending on whether you still have AC compressor and power steering pump still attatched).. its easier still if you remove all that and attach after the engine has been dropped in
When your finished come up to sydney and do mine too :P
i'm thinking of dropping out the bottom. lifting shell up and draging out box and engine on a trolley.
i've already undone all the looms etc, just waiting on an engine crane to get it done.
i might try take the plenum off too as it looks like i'm going to hit the hicas shit. or move that out of the way whatever is easier
yer i would if i loved putting motors in but unfortunately i hate it, im not looking forward to it
i almost ed considered paying a workshop to do it
bloody engines in & out! it's a pain in the ass , ain it?? :ninja:
something most rb owners experience hehe
i think it's easy, i just normally leave it to Mark!! actually he tells me to f##k off as i just get in the way.
mind you it''s so much harder on a road car , generally!
true, no aircon and no hicas really helps. we did it in 3 hours 2 weeks ago, + 2 more hours to strip the motor to see how much damage we had done. going back in this weekend hopefully but that takes longer (no point rushing that and finding a coolant hose under the rear of the plenum is wrong)
As long as you can lift it high enough its easier from the top and as one unit ( engine/box) . the car has to be off the ground on stands so the whole unit can fit, its a very long unit . I never remove the steering rack, the air con compreesor can be tied to the rail and the m6 bolt that holds the power steering line on the drivers side has to b e undone. Careful not to bent the cluch lines with the plenum and drop it in nice and slow while someone is watching as it is a very tight fit.
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
