[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
I'm trying to start some intrest in a group buy on Shafts.
i need to get 10 to get the price of $1400Us delivered which is a great price!!!
The Us dollar is looking great for buyers so hopefully we can get the numbers up quick!
I beleive they will be making the shafts for any length so any model will be good to go!
The price is 1400us delivered if we can get 10!
I will keep this running for as long as possible as i want 10 done!
the price for under 10 will be arouind 1500us without delivery which is about 250 each.
List:
Angus Smart
manage13
Merli
Mr. Keets
NIZ-26T
Edited by Angus Smart
  • Replies 717
Who is supplying them? Where are they being made?
Woops sorry about that
its from ACPT in the Unites States.
i beleive they make shafts for trust and someothers..
Cheers
Andrew
Cheers
Andrew
I just placed an order for 2 with James at ACPT...This is an excellent Group buy.
Just a couple of day late....I will e-mail James to see if these 2 can be added....but doubt it.
Phillip
Phillip
Oh nice, well i think it will take a few months to get the numbers up.
http://www.skylinesaustralia.com/forums/Gt...80&start=80
is where the discussion for these spawned! we wernt too sure if 10 would be able to happen.
Andrew count me in for 1 but I'll only have the funds available in 2 or 3 months. Will that be ok?
Hopefully it will take about that much time to get the numbers up :)
but your on the list :P And pray our dollar gets stronger, and theirs weaker!
how much do they weigh ?
I'll email them today, and get some more information from James
Here's a reply i have just in now.
"These shafts are rated for 1000 ft/lbs of torque. I can also make a high
horsepower application that is $100 more per shaft and will hold up to 2000
ft/lbs of torque."
i replied with a question about weight, and also as i need an odd length shaft questions about that.
Interested.
I'll be in if this gets off the ground by the time I'm ready for one. 10 is an abitious target though!!
Stuff it! I'll take one at US$1400.00. Does that include delivery to the West?
Hey mate, i beleive the delivery is to anywhere, as i beleive they are bieng sent seperate.
Sweeet, we're almost half way there! tho there are a few who are not so sure yet..
.........hmmmmm... Put me down for "partial interest" Angus.. ie if you've got 9 and you need the 10th, I could be in. I am sitting on the fence about this because although I understand that rotational mass makes more of a difference than just removing weight, the tailshaft isn't very big in diameter.. And it doesn't do big revs in 1st, 2nd etc.. so I am a bit perplexed as to if it would make a 'noticable difference'.. having said that I read somewhere else that some think it makes quite a lot of diffence. What am I missing?
Has anyone here actually put one on and done an A-B comparison? I'd be keen to know..
GTR-STI, have you noticed an actual difference?
Giant?
You might be better off reading a thread in the motorsport section about gtr weight.
someone explained it a bit in there. but you could also re ask them questions there too.
put me down for one and do they do one for front drive input for Bnr32
That shaft is already very light, it would be a good idea, but i dont think there would be a great deal of gain in it as its not a full time shaft.
Hopefully the attached picture will entise a few extras for you.
They are normally $1700US....this is a great group buy.
Hey mate,
Thanks for posting the pic... I assume that this is the ACPT one?
From that pic though, it looks like a metal shaft (I think I can see welding at one end?) with a carbon sleeve over it?
Can you confirm, and/or if at all possible upload a better/high-res photo?
Cheers,
Andrew.
:D
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
