[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
Yeah thats the email i read too. but it wasnt in the main body of it so i kept skimming past it.
i will know more maybe tomorrow or monday / tuesday.. depends what he has found out.
hes trying to screw the shipping charges down to compensate!
  • Replies 717
I didn't see that email, and I don't really have the inclination to go through them all :) But if that's true, then I have no problem with paying the extra amount.
Clearly stated in an email = Fair warning.
Merli! Now you're going to have to fork out a little extra for the shaft, I think I should do the right thing and offer you $298.70 for those tension rods you have for sale...! Y'know, to help out.
:) LOL
$90 odd i can deal with, but still want the shaft within a week time frame not some sent by boat takes a month etc crap where i have a feeling he is trying to cut the cost down...
Edited by 34tomidnight
:D LOL
I don't have the extra $100 for this shaft, so everyone tell Matt to buy my Cusco tension rods for $340 delivered :laughing-smiley-014: :laughing-smiley-014:
Otherwise I'll hold up the final payment for these rods and NO-ONE will get them <insert evil laugh> :laugh:
Yep iam happy to pay extra as well, is their going to be a difference in price between the guys who paid for the 1000hp model to the guys with the 2000hp model i think their was only piggaz and myself going for the lighter /cheaper shaft
Yeah i'm sure there will be a difference, tho at current its the postage we're working on to screw down in costs.
we're charged around $250, and paul also gets alloy shafts from somewhere else in the Us for 100 or so delivered.. so he's looking at that approach to get costs down for us.
I'm sweet as with the extra coin..just let us know and lets get these babies on the plane. I'm back in Jappa tomorrow so will have access to computer again..Pick up me car from HKS tomorrow and cant wait to see how it goes!!
Just out of curiosity. Is there anyone that will be doing a back to back test to see if there is any noticeable change in anything?
Hey Andrew,
It's been a while.
Please let me know how this debacle is going...
Can I enter the group buy at this point? If so what price?
Thankyou
Mick
Just read from start to finish, i hope after all this drama you guys buy Andrew (Angus) a beer for the effort he's put in
Oh, and i also hope you guys see a large difference in performance :D
Hey Guys, I've been away at the snow while there is snow still there.. gotta make use of the season pass while i can..
i have 2 emails from Paul,
we were getting charged around 300us for postage from Acpt.. which was all included..
Now.
Paul also orders shafts from other Us companies some of which are heavier alloy shafts and he gets them in here for around 130us which will probably see the difference in price there.. and possibly only a small payment to be done.. Paul is working on all this.
hopefully we will have some action this week and get them sent out,,
Now Michael. Wayy too late.. unless someone here wants to sell theirs to you?
Cheers Andrew
anyone sick of it all want the money back? I'll pay you whatever you have paid to date and take your order...
please pm me.
Cheers
Michael
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
