[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
Bloke there is no way the oz dollar will rebound ..I hope were not getting stung again
  • Replies 717
Happy to say i received mine today, thanks heaps for all the $^%#ing around u did Andrew.
Great deal & great job in the end, all good things take time.
Thanks again M8
quit all your bitching and complaining, they are here!! :banana:
tho i wasn't home so i have a little white note to fill out.
seems like your going to get them very soon :P
Cheers
quit all your bitching and complaining, they are here!! :)
Cheers
ahh the epic journey is close to the end. The highs, the lows, the creamy middles...what did I order again? lol
Well done mate :P
Thats sweet you guys got em..Hope mine rocks up next day or 2 as got some suspensions parts due in as well.
Andrew, thanks for all work, just hope there is no fall back to you on the oz dollar drama.
good news fellas.
I'm hoping mine pops in tomorrow.
PS - is there a marking or part number to differentiate between the 1000 & 2000 lb/ft shafts or whatver they are rated to lol ?
cheers
Edited by wrxkilla
cheers
lol im keen to know this too ^^
Havent got mine yet but Thanks for all the work Andrew, in all seriousness, would you organise another GB after all this!?!
as for the power ratings, it was actually torque rating, 1000ft pounds and 2000ft pounds. but i was sent hp this and then hp that. i think it changed when we went to the aussie distributor as James was always quoting torque ratings. (as i just copied and pasted)
Well i dont plan to buy anything for a while now, since our dollar is up the shit.
there is really only one thing that i might do which is a titanium exhaust (90mm trust cat back)
and possibly a sump extension (tho i can get sump extensions rather cheap thru a fabricating friend) who wants me to collect rb26 sumps so he can stock them.
he did the design himself. but its some what similar to how the hi octane one is. (welded in trap doors etc) without a cast item and with alloy. says if you happen to hit it the cast will crack. where the alloy will possibly dent or bend.
i'm actually waiting at home now as i must have just missed him yesterday morning with the delivery!
Its actually a bit heavier than what i expected.. tho alot lighter than normal..
maybe i should have gone for the lover model haha.
i did take a photo but found i have no usb cable here
awesome
is yours the 2000lb/ft one mate? how can you differenciate?
cheers
mick
yeah this is the 2000lb/ft model, and i actually have no idea, we will have to wait untill Piggaz or gtr13 take photos of theirs as they were the only two who did the 1000hp model..
mines around about 9.3cm in thickness.. on the carbon section.
Andrew
90mm Ti exhaust ay?..mmm if you wait on the dollar to regain some ground i'm in...Trust TiR? or do you have a cunning plan?
yeah just a trust ti-r 90mm..i think they weigh less than the carbon shafts :P or maybe they were 15kg's i cant remember
with the way i am thinking i should leave the current setup for now. and doing a sidepipe..
but it all comes down to my internal wastegates holding pressure (30psi) and turbo efficiency, if they are efficient and not holding boost i will go external and will want a new front pipe and the Trust catback..
but if they are all good, i will just keep the current setup and get a sidepipe made up..
yeah I think the 1000ft/lb one is the go. no way you are going to put 2000ft/lb through a GTR driveline. go for the lightest one. and even better it's cheaper! though I guess this sterling advice comes a bit late for you chaps... :P glad to see you all got there in the end. :D
I dont know if mine has arrived yet. I sent it to my mates house. My parents would shoot me if another package from another country for the GTR arrived!. Will post pics ASAP!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
