Hello,
Just in the process of installing a rb26dett power fc into my rb20det and i have purchased a boost control kit and it has to plug into the standard boost solenoid. After a bit of a look around the engine bay i have found this thing with JECS written on it. I looked at a non turbo rb20 and it didnt have it so its looking good so far. Am i correct, is this the solenoid im after?
Also wondering if anyone knows whether or not the rb26dett and rb20det have the same plug on the solenoid?
thanks
https://www.sau.com.au/forums/topic/208787-standard-rb20-boost-solenoid/
the pfc kit is meant to plug into the standard boost solenoid... has anyone with a rb20det and rb26dett pfc ever fitted the boost control kit? I havent got it yet its on its way, and computer is only half in, so i dont know which plugs come with it but im trying to sort it out befor i get it so its easy smoothe intallation
yeah but i think i might have a problem, as fc and boost control kit is designed for a rb26 it should plug into standard 26 solenoid... but i wonthave one.. hmmm
any other thoughts?
I got no idea what that thing is (isnt not present on a BNR32), I'd suggest that a metal box with only two thick wires going to it, isn't your boost solenoid :)
The boost kits comes with a solenoid, similar looking to the ones used in the AVCR and E-Boost setups; u don't use the original.
R32s don't have a boost solenoid as stated above
You should get one with the PFC boost controller kit and reroute waste-gate lines to run off the solenoid provided
That way you can wire the BC kit off that
No idea what that metal box is but when someone finds out can you tell me too please
do rb26's have a standard solenoid?? Cause the pfc bc kit is made for gtr33 same as my ecu. So it probably wont come with a solenoid if a 26 has a standard solenoid.
also that silver box, befor thinking it was a boost solenoid i think it might be a resister pack for something
Resistor pack - thats what i orig kinda thought.. but they have a lot more then 2 wires going into it, plus need boost lines as well :P
How ever much it will help, uploaded a picture from my BNR32... years ago, please don't laugh about it looking like Kosovo.
Stocko boost solenoid is to the right of the relay box, with boost lines going to it. I think R33's are the same.
Edit:
"Doh, posted b4 refresh'n - as above, I know R32 GTR's have em, i ignorantly, assumed all R32+ Skylines did :) ...
Regardless, outa my league but I'd say the boost solenoid comes with all PFC Boost kits... as this quote
"The high grade solenoid valve is the same one used in our Apexi Super AVC-R boost controller."
From This Link
Edited by GeeTR
This thing is a relay for the fuel pump if I'm not mistaken. It sends something like 9v to the fuel pump on idle, to minimize fuel consumption. U can tear it out. Nobody needs that.
Spot on its a resistor for the fuel pump.
yeah that silver box is for the rb20det injectors.
Na its not, maybe your getting confused with the resistor pack the GTR run, they look similar but RB20 don't use them as the injectors are high impedance anyways
hmm so what happens if you rip it out, 0v at idle or full 12v at idle?
While I'm here, does any PFC boost controller kit work with any PFC?
I have an AP Engineering RB20 PFC and I don't even want to thinking about looking for/finding a BC kit to suit that.. was hard enough finding the PFC it self
Eg: Would an R32 GTR BC kit work on my AP Engineering RB20 PFC?
:laugh:
The car will start then stall if you have it unplugged, so i'd suggest 0 at idle. Technically you have a break in the circuit.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
