Anyone can help here?
I'm trying to think which is the best to go for?
Obviously i'm chasing the best response and yet provide with the power i'm chasing.
a Garrett GT2871R with .63 rear housing or
Garrett GT2876 with .86 Rear housing or
Garrett GT30 all with ball bearings
I'm chasing power between 300-330kw at the rear wheels
It's to go on my R33 with RB25DET engine that has:
2mm Cometic head gasket
Tomei heavy duty Valve springs
264 in/ex cams
3.5" exhaust
Walbro 255L pump
WOLF 3D V4 ECU
HKS Boost Controller
38mm Tial External Wastegate
HKS Cast Iron Low Mount manifold
FMIC
Filter
Front Face Plenum with 80mm throttle body
SARD 550cc injectors
Splitfire Ignition
Iridium spark plugs.
GTR Radiator
Adjustable cam gears.
Think of changing my Walbro pump to a Bosch 044 pump with a surge tank instead but i don't know if it's necessary or not, What do you guys think?
Edited by Deceeve
https://www.sau.com.au/forums/topic/209372-need-help-on-turbo-selection-guys/
My choice would be GT3037 .82 run at 22-24psi (as im doing) that way you will have good response and will achieve your power goal.Rather than buying a bigger turbo with more lag. But having that 2mm headgasket it will be a bit doughy down low.
Frankly if you are targeting 300kW as a minimum, you'd do well to head straight to a GT3582.
I noted that your shopping list / parts list includes an external gate, so any of the GT28 series stuff won't be suitable or cut it from a flow viewpoint anyway.
Suggest doing a search, using either GT30, GT35, or 300rwkW as key words for turbo specs. There are a few blokes who have exceeded 300kW but you have to make sure it lives a reasonably long life by giving it the right supporting systems.
I hope your fuel system and engine breathing system is well thought out. If you're actually going to use that power (ie at a track) then cooling (radiator and oil) should be factored in. Get rid of the Walbro, use a Nismo in tank pump.
Keep us posted with updates please, and good luck.
i dunno go the smaller frame turbo and stick the temp probe in a cup of coffee and bob's your uncle. :)
nah, i'm with dale. wringing the neck of GT3076 to get there might be more trouble than it's worth.
Edited by wolverine
Wouldn't the GT2871R white achieve around 300rwkw with very minimal lag especially with the 2mm head gasket?
if running the GT3037 .82 what RPM does the boost comes on and when do you actually hits full boost though?
Is the mods in your car much different to mind?
I'm just not sure how early i can get the turbo to come on boost early enough with the thicker head gasket you see and yet still achieve the goal.
With the 3037 id imagine (in my car) i would see full boost (22psi) by 3800rpm,but i will have a Greddy plenum,cams and an aftermarket exhaust manifold.So might be a little later in your application.
I've already got that mods in my car and is now using the Hyper Gear TR44 and turbo seems to be surging. It comes on boost like so late of about 3500RPM with not even enough G-force and then just die so fast at about 6000RPM. Giving me no power to play with at all.
Not going to be using it on the track just weekend car for cruising or something. With the mods i have wouldn't the GT30 or GT35 makes it alittle too laggy especially with the 2mm thick gasket?
I was thinking of going for the new Turbonetics T62-1 Dual ceramic ball bearing and it is a patent developed by NASA :)
The walbro pump i have is also an in tank pump but what makes the Nismo one more better?
I forgot to add that my fuel system is a sard 550cc with using Splitfire Ignition and Iridium spark plugs.
Will keep everyone posted on the projects.
So you're saying even with the aftermarket plenum with 264 cams and HKS low mount exhaust and the 2mm head gasket i would expect full boost to hit a little later than 3800RPM?
I'm only after anywhere between 300-330rwkw but is also considering the Turbonectics dual Ceramic Ball bearing turbo it's just that i haven't heard anyone in OZ used it before on a skyline especially since it's just new as well. It's rated at 600HP with .63 rear housing.
Mate the 2871 wont even come into the ballpark. Turbo homework you need :)
Max of around 250rwkw on a good day.
Simply put, 300rwkw you ain't going to see anything resembling "response" until after 4000rpm, 4200-4400 is more likely.
And on a stocker motor, GT35, your gonna be limited with RPM range upto 7500 at the most being I wouldn't go much further without uprated rod bolts in the bottom end more so than the coin you spent on the head as the bottom end is the more critical part of it IMO
Mate the 2871 wont even come into the ballpark. Turbo homework you need :laugh:
So in your ipinion with the mods what do you think the best turbo to get that power?
That is crap.
It will not make that much power, and if it did, it would have the engine on the brink of destruction.
Either that, or you like using happy dynos.
Darrens S14 drift car is an example. As for Alberts S15 making 280rwkw on 15psi with another. I'm not talkin the T2 flanged butcher special either. Theres no reason why a T3 flanged GT3071R cannot make that sort of power, altho it will be stretching its legs. A quick read thru a thread just below this turns up;
http://www.skylinesaustralia.com/forums/30....html&st=20
290rwkw with a cropped version! Well then 300 should be no probs with an unmolested GT3071.
Edited by Busky2k
its true... mine cranked 290 rwkw the other day with a cropped 3071R, and 1.2 bar boost to do it. i was making 265 rwkw on 1.2 bar, then chucked some cams in it and now its making more power on same boost.
the 3071R is an awesome all round tuerbo for response and power... they will make 300 rwkw, but not anything massive over that.
I wouldn't mind seeing some of these dyno sheets so I can see just how much the dyno operator has fudged the final power readout.
I have a 3076 with water methanol injection - and it struggles to make 310rwkw on 18psi of boost.
How could a smaller turbo make it just as easy?
there are examples of some extreme results both high and low for any given turbo. given a choice i would shoot for lower peak power output and go a smaller framed turbo every time but this is dependent on use hence it is a personal choice.
simon-R32 has an amazing result out of the GCG cropped 3071 turbo. i am aware of a workshop has struggled to make power with another example of the same turbo. since GCG are highly reputable it is a real headscratcher why one is shooting the lights out and another hasn't gone close. i would have expected simons to top out closer to 270-280rwkw with cams and the great response with the extra care in the tuning and setup.
if 330rwkw is the target i still reckon GT3582
Edited by wolverine
why do you want 300 - 330rwkw's?
does that sound like a nice figure?
personally i would choose a .82 gt3582r but expect full boost around 4000 - 4200rpm
pull hard to 8k happily make 300-350kws depending on boost.
gt30 is at the end of its chain working that hard, and is the same price as the gt35 so why stretch it when you can do it easily.
my gt3582r-iw, with a high stall auto, is still managing 320rwkw on 23psi and no
knock, on shell v power.
my old gt3071 with the auto was out of puff around the 270kw mark
and remember to be prepared for a $10k rebuild either way at those figures.
The reason i'm aiming for that figures is that i'm still running on stock bottom end and i believe that's the safe figures i can push it to for the R33.
I think the GT3582R would offers that power but don't you think with my 2mm head gasket it would be pretty damn laggy?
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
