  • Replies 47
the weird thing is the story in the telegraph is completely different to the one online at smh. in the DT story the bloke was driving and the girl was a passenger, and he didn't slip away whilst they were arresting the female, he apparently confonted them with a knife and somehow overpowered them and took their paddywagon.
I find that hard to believe. He would have been sprayed or shot if he did that.
hmm my thoughts also, they would have used one of those methods im pretty sure.
Police just stuffed up and are trying to cover their tracks no doubt
they are full of poop! The girl was the driver..
He bolted into the cop car and sped off.. we saw it.. I would have felt like a total idiot too if I were one of those cops and had the patrol car stolen.
Seems a mix up...they didn't steal anything, they reclaimed the toyota as part of their entitled reparations. It broke. Then they laid claim to the police car in exchange for the toyota..Policemen like toyotas so he said furry muff fella on yer way........ then Kevin & Julia lived happily ever after!
better watch out people, theyre gona need to hand out alot of defect's to pay for that "misplaced" cop car.
Narp they'll just write it off against the new indiginous housing project as a moble home :thumbsup:
Not all cops are tops, but not all cops are tossers either.
Stop with the cop bashing, I know some like to defect but it's the law. And to those that say cops are lazy and don't do f**k all. If only you knew the amount of work they do.
Try working for a legal system that hands out legal aid to Sh*t bags that steal cars like ours and get away with it. Reason - the legal system is designed in such a way that it works against cops. If you don't like the cops here, go f**k off to America, they'd try getting you for the most trivial sh*t.
I hate when people talk about sh*t they know nothing about.
how long does it take to train to be a cop? 6months like those advertisements say?
Plus 12 months as a probationer (on the job training) and every year after you have to pass a physical and you must pass your shoot (must hit 30 of 36 targets in a set time - as I recall) and tactical training - where they put you in a situation involving firearms and other weapons.
People here talk the talk but can they walk the walk... Doubt it!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
