Hey guys
Ive been getting a few p.m's recently asking about the reults ive had with my HKS 3037 Pro S turbo, instead of answering them i thought why not make a new thread lol.
Anyway i had the car tuned yesterday so here are the results
Mods:
Stock Internal RB25DET
Stock intake/ehxaust manifolds
HKS 3037 Pro S turbo kit, 56T A/R 0.68
HKS adjustable internal wastegate
HKS Stainless steel split dump pipe
HKS Front pipe
3" decat pipe
HKS Silent High Power stainless steel catback exhaust
HKS 3" alloy intake pipe
Apexi Power FC
Apexi Power FC Boost control kit
Apexi Power Intake Pod filter
Blitz LM Front Mount Intercooler
Nissan Z32 AFM
Nismo fuel pump
Nismo 555cc injectors
R.I.P.S oil catch tank
Exedy heavy duty clutch
Splitfire coils
Alloy radiator
NGK BCPR6ES spark plugs
The car made 270rwkw on 17psi and running on crap 95octane fuel, Tuned by Andre Simons of Speedtech Motorsport
Im very happy with it considering the fuel im using.
What you guys think?
https://www.sau.com.au/forums/topic/209907-hks-3037-pro-s-results/
top results mate :D
getting a 3076r strapped on atm. my power target is exactly what you got - 270rwkw at 17psi.
how well behaved is it on the road?
Actually its real nice on the road, 2nd tends to just grip on and the car takes off, but will spin the wheels if you try to, 1st actually grips pretty well to from what i have felt so far, i havnt really tried 1st that much yet to be honest.
Boost comes on fast and it just takes off, its dosent kick in like a switch at all, its a bit hard to explain, but even in 5th gear it still hauls!
why are you only running 95 oct fuel?
Thats all we have in my town, i could have used 98 but that would mean i would have to drive 15mins to the petrol station everytime i want to fill up which is a hassel.
98 would have been great though, if we had it here i would have used it for sure.
Edited by nizmo_freek
98 would for sure. No doubt about better fuel equaling more power if the tune is there to support it.
Dyna pack read a bit higher than out Dyno Dynamic from what most comparo's show here being 15psi/270rwkw usually is what people make here on 17psi with the same turbo etc.
Great result, boost holds nicely too, very minimal spike.
Good to hear the delivery is good, i would have expected a tad snappy with the smaller rear personally... but then that could be the tune somewhat as less ignition is flattening it off just enough for perfect traction by the sound of it.
Would make a good street car :D
Hey mate, nice results!
Could you post up pics of the turbo in your engine bay?? I have one of these on order and should be here in a week or two :D It would be great to see what it looks like
Hey mate
Heres some pics, its all i have at the moment, kinda hard to poke around in the bay with a camera trying to get decent pics, but if you need anymore p.m me and ill try ad get some.
I dont have the turbo heat sheild installed in these pics, i took if off so the tuner coul play around with the acuator a bit.
Cheers for the comments guys :P, really happy with the car.
great power figure, do u mind giving us the ball park figure of total cost. boost does hold nicely n i'm sure u great a mixture of great power along with good responce! nice streetable r33!! hame
Do you mean a price for just the turbo kit? or everything like turbo, injectors, afm, intercooler, clutch, exhaust etc etc??
both! :)
Im looking at a very similar setup and would love to know what sort of price ill come in at.
Cheers
Turbo kit was around $4000nzd, which is alot cheaper than other places are selling them for (i have seen gt-rs kits sell for over 4g), then add atleast 6g nzd for all the supporting mods, thats exhaust, cooler, fuel system, ignition, clutch, etc etc, i could have done it alot cheaper by using cheaper parts, like custom steel exhaust, cheap chinese cooler, cheap fuel pump, etc etc, but i chose to spend a bit extra and get things that fit perfect and have been proven plenty of times to work, it could be done alot cheaper if you wanted though.
:thumbsup:
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
