Sau-vic @ 2008 Ing F1 Gp - Autosalon Display
Some pics prior to setting up the cars in the official lineup. More pics in Members Events section.
Dont forget to come down to the Autosalon area near the edge of the lake south of the pontoon bridge and say hello.
  • Replies 101
so they've shoved you in that area now??
i dont think im going this year
have fun with the weather though..get some waterfights going haha
That's an insane idea, I'm toast after today. Dehydration FTL!
Bec, you have to post up my gangsta pose :thumbsup:
HAHAHAHAH - the gangsta pose was gold!!!!
1. Watch muppets take pics next to Snowys car
2. Repeat it yourself
3. Laugh at the pics (Shane - all your missing was the Autosalon haircut :))
Hehehehe - James Ward :)
Mmmmmmmmmmmmmm
Ouch :D
SAU stand (the white tent in the first pic is the dyno, and the little silver car next to Ants car had a "if you dont move your car in 15 minutes we will tow you away" sign on it)
Random old dude we saw on the way home, walking down Inkerman St in his undies :thumbsup:
Thanks all for a good day.
See you all in the morning, im knackered - its TV time for sure now.
RBPOWR i think the plates, i saw this thing at mi colour
RH9!!!!!!!!!!!!!!! its damn sexy
just aswell as the blue r34 gtr!
DID ANYONE SEE THE OLD SCHOOL GTR!!!! ITS bollocksIN INSANE, i parked my car, looked at this thing under a car cover... i thought to myself.. "no way" BUT IT WAS!
id give both my nuts for that thing
lol RH9 - bean bags car is ALL speculation...
I think it ran a 12 before it imploded?
(i can see you reading rossco - i know you love it hahahahahhaa)
Which old skool GTR?
The HR31 GTSR? or something else?
I saw the old GTSR in the city Wed, tassie plates with the new owner etc. So im assuming its there, or was there for the rally?
(i can see you reading rossco hahahahahhaa)
HAHAHA once again your shooting your mouth off with ill advised speculation
It was an 11.05 @121mph....where I only had power to the wheels for the first 200m...not 12 seconds you buffoon
And where is your busted old pintara BBQ?.....Still waiting to get fixed.
Me = Proof it works and is real
You = chasing a box shaped dream
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
