spotted a pearl white V35 at the end of M4 parramatta road yesterday morning. Asian chika driver.
also spotted a bluish V35 along James ruse drive crossing Great western Hwy.. was raining hard couldnt see properly
spotted a guy driving a silver v35 stock looking at orange grove on Thursday
he saw my car and proceeded to drive like an absolute cock head
then, as i tried to say hello, gave me attitude and left
wtf is the world coming to?
coming to.... an end.. all moral flush down the toilet..
He had probably just stolen it!!!!!!
I see a few V35s a week going to Epping from city. No one seems to wave these days... In the beginning, everyone waved at each other.
Dam if i seen another V35 i would be hanging out the window waving like crazy, beeping the horn, flashing the lights and yelling "HEY LOVE YOUR CAR" :P
I flash, beep and wave at every V35 Isee, but as yet, nobody has reciprocated.
Speaking of which, I keep seeing 2 black examples: 1 is always parked at the industrial estate at Ernest, and the other is always on/turning onto Southport-Nerang Rd in Ashmore. It has personalised plac=tes: can't remember whatv they say, but they are gold text on black background...
Ok I've seen at least 9 different Vs over 3 days on the same street .. Quay Street at UTS... 5 silvers.. 2 blues.. 1 black.. 1 red.. every colour of the v35 rainbow...Someone here has to be one of them
On of 2 blue ones, might be me.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
