Ok the new injectors,valve springs and engine mounts arrived.But it looks like i have wrong mounts :banana:
The ARP exhaust manifold bolts also arrived,and finally that completes all the ordering for the build.
Now its all the small things i have to the running around for.
Things like a universal mount for the Greddy oil catch can.
Getting the rocker covers painted.
Working out the lengths for all the braided lines.
I have to clean the engine bay :/ im trying to think of a way to clean it without removing all the lines and hoses.As its not that dirty im thinking of spraying the front clips and fire wall with some sort of cleaning solution,letting it sit for 2mins and hosing it all off.Then hopping in with a rag to get all the stubborn stuff.
What would you recommend? Quick detailer? Maybe something a bit harsher?
gurny? :banana:
if you've got a compressor just hook up some hot water mixed with concentrated degreaser (which you can get from bunnings) into one of those spray can things you can get as an attachment. would probably be better for getting the grease off cause you can mix degreaser into it. thats what i do.
Once it's getting reassembled and you've worked out exact dollar signs it'll come together and you'll start to feel great :blink:
I'd love to do what you're doing, looks exciting and engrossing. You'll be having some serious fun when it's complete :)
Love the pics. Keep em coming.
Dont work out the exact dollars; it ruins the enjoyment!
OK all, today everything was delivered to Paul. Top bloke :P and was even lucky enough go for a blast in the GTR. Which was insane! Its not everyday you get to ride in a genuine 9 sec GTR :D
BP98 with 6 deg total timing removed @ 15 psi and 1/2 throttle is not really the way to show off the car...
but...
im sure you got the idea how nuts it is to drive. :D
Edited by DiRTgarage
Just another small update.
When i bought the 3037 a few months back i noticed it had a 4 inch diameter inlet,and thought i would have to either put a 4inch step down to 3inch silicone joiner on the turbo or try and hide the joiner in a custom CAI with the AFM,as the AFM diameter is 3inch.Neither of them tickled my fancy so...
It just so happends, i managed to get my hands on a Haltech E11v2.
So my beloved Power FC and Z32 AFM are for sale.Look in the for sale section for the thread :laugh:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
