Ha. I wish. Give me time to kill this one :cool:
I want to get the car engineered so im getting a few little things sorted out plus a body kit fitted and painted.
Im also seeing some of my mates making crazy power figures, so a slightly bigger turbo might be on the cards.
I forget, do you drag race? I'd love to see what yours would do down the strip, I'd have thought that it'd be in the vicinity of 10s on decent tyres? Surely there must be some temptation to bust out a real fast time like that using far less turbo than most do :thumbsup:
Ha. I wish. Give me time to kill this one :thumbsup:
a t04z? dont do it, keep the 35 on it with a .82 and spend money on the head. that should see close to 600hp at the tyres with everything working properly
Dave ive got a nice twin scroll turbo here on the shelf. Its a little larger than what you have now that you can borrow for a 'suck it and see' test session if you like.
Come pick it up if interested.
If i do decide to upgrade the turbo it will be a GT35R .82 w/ported shroud like the 3076 i have now. Love the sound of it spooling :D
Also might see if i can get the collector cut off the manifold and have a split pulse one welded on.
It is a difficult choice, as the response VS power of the setup now is insane.
If i do decide to upgrade the turbo it will be a GT35R .82 w/ported shroud like the 3076 i have now. Love the sound of it spooling :)
response is king for circuit and street
i personally think you would be insane to do this... a friend had a rb25 neo with cams, greddy plenum etc and was a cop with a 3582r, convinced him to downgrade to a 3076r and now its awesome!!!
Edited by Cerbera
i personally think you would be insane to do this... a friend had a rb25 neo with cams, greddy plenum etc and was a cop with a 3582r, convinced him to downgrade to a 3077r and now its awesome!!!
REALLY?
my Mechanic got a 33 tuned with a 3582 with a .84 rear and got the lag down from 4200rpm to close to 3200-3500rpm.
To me that is bloody good, keeping in mind the size of the 3582. That is almost the same amount of lag as my .63 3582, bloody amazing.
Edited by r33cruiser
Do what you said above, split pulse the manifold and go a split pulse GT35 - probably will be never quite as good as the GT30R but closest thing to having your cake and eating it too :thumbsup:
i just put a gt37r on a supra, you know you want to. do it. :):thumbsup::laugh:
Is that the one softy was telling me about?
How does it go up macpass?
id love to hear what you think as ive got the gt3566-82r here waiting for my supra
New workshop looks the goods!
If i do decide to upgrade the turbo it will be a GT35R .82 w/ported shroud like the 3076 i have now. Love the sound of it spooling :P
Mate call up GCG and talk to them about a 66mm front fan ;)
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
