Probably sucking from the sump and then feeding into the front of the main oil gallery that the pump would. Then oil flow can just continue as per normal. Looks like a good setup! Just make sure you get some anti run off guides for the pulleys to keep the belt from ever jumping/running off.
Yeah I was thinking this too. Looking at the pump pulley and thinking it looked weird, then noticed the belt could potentially just slip off. LOL
There really are only pro's for having one. Who needs or wants air con anyway?
we live in australia where it regularly gets to 35c for weeks on end, who on earth can drive around in traffic without it? I guess if you have no issue rocking up with sweat patches over your entire upper body to work it isn't a real issue though.
Edited by Rolls
I barely use the bloody thing. Only ever hit the AC button to demist windscreen or to make sure the bloody seals in the pump didn't get stuck and die.
Now that I've had issues with the ViPEC never letting me turn it off, I've taken the solenoid out for the pump anyway lol
I guess the aircon is a problem for alot of people who are used to modern day comforts.
However, if you are building a wild car/engine, such as the one in this thread then its really not that important. Having a near bulletproof oiling system that can handle stupid amounts of abuse is :banana:
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
