well it might be actually possible, would need subframe off, sump off, crank out, balancer off, timing gear off, timing belt off, oil pump off, gearbox off, clutch off and flywheel off.
but if you did all that you could probably get to all of the bearings.
seriously though, if you need new big end bearings, rebuild the motor. the main bearings are probably in trouble, there is most likely some crap floating around somewhere, might as well do a hone and new rings while you are in there. pull it apart, clean and check it all, put it back together. so much damn work just to get the sump off
You wouldn't have to remove your crank to change B/E brgs. I've changed them on various other motors in the past by removing the B/E caps & spark plugs, pushing each piston up an inch and being real careful not to nick the journals with the thread on the B/E bolts, if you do, crank has to come out (might have to come out anyway for a grind or at least a linish if its got grooves).
You'll have to do a r & r on each cyl that's on the down stroke then turn crank to do others.....pretty messy this way but good oportunity to replace with a decent baffled sump.
As far as mains are concerned, they rarely fail unless there's crap in the galleries but usually evident by pitting or scratches on the B/E shells.
You CANNOT get the sump off with the gear box attached, there are two bolts behind the flywheel. This has been covered before, It is not practical to take the box out, to remove the sump. Just pull the engine, there is no way around it. And yes, I have done it.
Sorry to be a spoil sport
ok thats fine.... just wanted to find out first as i have never worked on a rb26 befor motor has only been rebuilt not long ago.... it got low on oil and now has the knock at around 3 4000 ill get some one to do all the work and check every thing
might be time for the bigger turbos at the same time :domokun:
Fair enough, its good info to know. As I stated above, I have removed sumps on various other motors whilst still in the car but not on an RB, thanks.
yes so have i thats why i asked.....it has cp pistions and a baffled sump ect all ready and light weight rods im not sure what type of bearings were used tho any ideas on how to tell?
Check numbers on the back of the shell, may give a clue, or if your not using them again light scrape on inside will tell you if they're copper leads or alu tins. Always a good idea to use a copper lead or similar in an RB though.
Huh??? Same thing....you gotta remove the B/E cap to remove the B/E brg. What sort of other B/E is there?
Where do you think the big end bearing sits, and what does it protect? The Big End (it's the end of the conrod that connects to the crankshaft).
If you are referring to the big end bearing, then call it that.
Been in the engine reconditioning game for 20 years mate so I appreciate you teaching me something that I learnt when I was still in nappies.
When engine reconditioners say they're changing their B/E's, they're always referring to shells. Otherwise they refer to the rods specifically. They never talk about changing B/E whilst referring to rods.
Sounds like you like to make a play on peoples words and argue pointless issues otherwise you wouldn't have asked such an obvious question.
Sorry, didn't realise you had so much experience in these matters.
Yes, I can be a pedantic old bastard sometimes. It's just that there are quite a few younger members who don't always understand the technicalities.
And the only stupid question is the one you don't ask.
Yeah no probs bud, I know what you mean & I agree, its like banging your head on the wall sometimes. :)
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
